Old 10-20-2015, 09:21 AM   #241
TURBS's Avatar
Originally Posted by gljurczyk View Post
That's kinda like the Norcold, When I see my freezer temp and refer temps with my accustat I know when to turn it to a lower # 1 thur 5, I also always travel with it on #1 when we travel less propane use. Then at the CG I will turn it back up to 3 easy to due a lot better then the slide on the fin. I'm sure you have some 12v computer fans on order for circulation inside and the back coils. I still say I would keep that progressive they put in. You got all winter to due your many mods. You know what you need and what you want for a top notch trailer and make it your own. This is not your First Rodeo. It sure is nice through hope you and Amy enjoy it. Hope you can find that extra kit that was mentioned for your JT'S. It would be worth it for the $20.00 bucks.It will not work right with out those brackets and brass inserts. There is an RV used parts just down from the Goshin fairgrounds when I was there they had stacks of rear stabilizers, I think that would be a great mod for you I still use mine after the 4 point levels me. I think it helps with the aft part of the trailer. ....
Kit on the way, ppl motorhomes is sending it free of charge.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-20-2015, 09:42 AM   #242
Wiscampsin's Avatar
Originally Posted by TURBS View Post
...Fireplace keeps the whole living / kitchen area warm without starting furnace! ...
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
When we factory ordered our Sabre DW was quite insistent on getting the fireplace. I thought it was more fluff than functional but was quite surprised and pleased how well it performs.
2013 Palomino Sabre 34REQS-6
Link to pics:http://s1340.photobucket.com/user/Wi...?sort=4&page=1
Old 10-20-2015, 09:45 AM   #243
Left Coast
How many amps do the fireplaces use?
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 10-20-2015, 09:55 AM   #244
TURBS's Avatar
Less then 15 amps oc w.
I'll look at the manual tonight and let you know, since I don't have my ems yet I can't check "actual" amp draw.
Mine has 5 fan settings and a temp setting.
Iirc it's 4,600 Btu ?
TURBS
2008 duramax
2015 columbus 320RS
Old 10-20-2015, 10:02 AM   #245
Left Coast
Before I bash cabinet in the head, are most of them a standard size and I'll wait for amp draw.
Old 10-20-2015, 10:06 AM   #246
CANADA FROG RALLY 2017
B and B's Avatar
The fireplaces are 1500 watt units.
Ohms Law
P- Power in Watts
I- Current in Amps
E-Voltage in volts
P=E times I then I=P divided by E.
Therefore, I=1500 divided by 120, so the current drawn is 12.5 amps.
We run Electric hot water, fire place and shut off to make toast or dry hair. Our Microwave shuts off the Fireplace all by itself. If we leave hot water on propane we can make toast stay warm and dry hair.
Clear?
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 10-20-2015, 10:06 AM   #247
TURBS's Avatar
Google "rv fireplace".
Many many options
I'll get you the name of mine.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-20-2015, 10:10 AM   #248
Left Coast
Don't need hair dryer here!
Old 10-20-2015, 10:14 AM   #249
B and B's Avatar
The white dog doesn't need it?
B and B
Old 10-20-2015, 10:15 AM   #250
Attachment 91955
TURBS
2015 columbus 320RS
Up to your Old Tricks,burning Pick nic Tables I see! Youroo!!
columbus, sabre
