10-20-2015, 08:21 AM
#241
Originally Posted by gljurczyk
That's kinda like the Norcold, When I see my freezer temp and refer temps with my accustat I know when to turn it to a lower # 1 thur 5, I also always travel with it on #1 when we travel less propane use. Then at the CG I will turn it back up to 3 easy to due a lot better then the slide on the fin. I'm sure you have some 12v computer fans on order for circulation inside and the back coils. I still say I would keep that progressive they put in. You got all winter to due your many mods. You know what you need and what you want for a top notch trailer and make it your own. This is not your First Rodeo. It sure is nice through hope you and Amy enjoy it. Hope you can find that extra kit that was mentioned for your JT'S. It would be worth it for the $20.00 bucks.It will not work right with out those brackets and brass inserts. There is an RV used parts just down from the Goshin fairgrounds when I was there they had stacks of rear stabilizers, I think that would be a great mod for you I still use mine after the 4 point levels me. I think it helps with the aft part of the trailer. ....
Kit on the way, ppl motorhomes is sending it free of charge.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
10-20-2015, 08:42 AM
#242
Originally Posted by TURBS
...Fireplace keeps the whole living / kitchen area warm without starting furnace! ...
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
When we factory ordered our Sabre DW was quite insistent on getting the fireplace. I thought it was more fluff than functional but was quite surprised and pleased how well it performs.
10-20-2015, 08:45 AM
#243
Left Coast
How many amps do the fireplaces use?
10-20-2015, 08:55 AM
#244
Less then 15 amps oc w.
I'll look at the manual tonight and let you know, since I don't have my ems yet I can't check "actual" amp draw.
Mine has 5 fan settings and a temp setting.
Iirc it's 4,600 Btu ?
TURBS
2008 duramax
2015 columbus 320RS
10-20-2015, 09:02 AM
#245
Left Coast
Before I bash cabinet in the head, are most of them a standard size and I'll wait for amp draw.
10-20-2015, 09:06 AM
#246
The fireplaces are 1500 watt units.
Ohms Law
P- Power in Watts
I- Current in Amps
E-Voltage in volts
P=E times I then I=P divided by E.
Therefore, I=1500 divided by 120, so the current drawn is 12.5 amps.
We run Electric hot water, fire place and shut off to make toast or dry hair. Our Microwave shuts off the Fireplace all by itself. If we leave hot water on propane we can make toast stay warm and dry hair.
Clear?
B and B
#247
Google "rv fireplace".
Many many options
I'll get you the name of mine.
TURBS
2008 duramax
2015 columbus 320RS
10-20-2015, 09:10 AM
#248
Left Coast
Don't need hair dryer here!
10-20-2015, 09:14 AM
#249
The white dog doesn't need it?
B and B
10-20-2015, 09:15 AM
#250
Attachment 91955
TURBS
2015 columbus 320RS
Up to your Old Tricks,burning Pick nic Tables I see! Youroo!!
10-20-2015, 09:27 AM
#251
Left Coast
No, he's fast........Turns, be send'n you a relic...look inside stove, a 30/40's rail road flare set....complete with launcher.
10-20-2015, 09:29 AM
#252
Saaaaweeet!
TURBS
2008 duramax
2015 columbus 320RS
10-20-2015, 09:53 AM
#253
Saaaaweeet! TURBS
Burning all the wood poor Ms Amy sweat over cutting and splitting this summer during the times she wasn't mowing the yard and working 10-12 hrs a day.
10-20-2015, 09:58 AM
#254
Left Coast
I'll bet the new 'house' is at where he goes during the day....lots of stuff git'n done in daylight hours!
10-20-2015, 09:59 AM
#255
Georgia Rally Coordinator
Saves on fire wood. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-20-2015, 10:06 AM
#256
TURBS
2015 columbus 320RS
Our fire place does the same sure saves propane. I was a little hesitant about getting the fire place as figured it more for decorations than functional. Glade I got it. Later RJD
Days camped 2019 62
10-20-2015, 10:33 AM
#257
I really does pump out some heat!
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
10-20-2015, 10:42 AM
#258
2008 F350 CCSB V10
2016 Sabre 36QBOK
I agree!
TURBS
2008 duramax
2015 columbus 320RS
10-20-2015, 10:47 AM
#259
In fact the dog like to sleep in front of it to keep warm. At night we do turn it off, need the furnace to circulate heat around otherwise the bathroom is very cold.
B and B
10-20-2015, 10:52 AM
#260
Left Coast
Next they'll be putt'n tanning beds in.
