Old 08-23-2019, 05:01 PM   #1
Gray water drains
My son and a friend of mine have 2018 and 2019 Puma 32RBFQ's. They were telling me that they have never gotten water out of the drain that is marked as galley. Before you ask the valve is open. When you run water in kitchen sink, it runs out the back gray water drain. The same as the bathroom sink, shower and outdoor kitchen sink. Can someone solve this puzzle?
2020 Cedar Creek 38DBRK 5'r
2020 Chevy 2500HD Duramax 4X4
jimla is offline   Reply With Quote
Old 08-23-2019, 05:50 PM   #2
Iwannacamp's Avatar
Couple questions.
Does it have 2 bathrooms?
Does it have an outdoor kitchen?
Have you looked for valve in the grey line ahead of the main drain lines?
2017 Puma 297RLSS
Old 08-23-2019, 06:15 PM   #3
Oaklevel's Avatar
Are you sure that it has 2 grey tanks by the specs it looks like there is only one tank. No galley tank. ???
When you say nothing comes from tank drain marked galley were are you looking?? On the info panel board ??? The boards are generic to many models.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 08-23-2019, 06:53 PM   #4
Does it by chance have washer / dryer prep? Ours did and we never got any water out of the ‘galley’. It turns out the ‘galley’ tank is dedicated to the washer drain. We don’t have a washer so no water into that tank.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-24-2019, 07:59 AM   #5
Chickdoe has it right. After posting, I was pondering over this and realized what Chickdoe was saying. Thanks for input.
Old 08-24-2019, 08:25 AM   #6
do both of the gray tanks drain out of the same sewer hose connection? if so, and you need to increase your gray tank capacity you cam buy an external twist on sewer valve and put it onto the sewer outlet. close this valve and open the two gray valves and the water in the gray tanks will equalize between then thus increasing you gray tank capacity.
drain, water
