Old 07-07-2014, 11:44 AM   #1
Greasing Slides
Do you guys grease your slide mechanisms? These are electrical and have geared tracks under the slides. (non schintek (sp))
If you do grease them, what do you use?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 07-07-2014, 11:47 AM   #2
NELA
Weezer's Avatar
We asked to have ours checked, serviced and lubricated, while it was in for some small warranty items. Have no idea which lube they used, but SHEESH! they're so much quieter now!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-07-2014, 11:49 AM   #3
Ford Idaho's Avatar
I use this.
Much less for the dust and dirt to hold on to.
Old 07-07-2014, 12:44 PM   #4
No grease, eh?
Old 07-07-2014, 03:36 PM   #5
H2oski
I use the dry film lubricant for garage doors. I use it on steps, locks, slides, jacks everything that squeeks I lube it. NO GREASE except on wheel bearings.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 07-10-2014, 05:32 AM   #6
amxpress's Avatar
Protect All Slide Out DRY Lubricant. Spray it on the rack and gears under your slide. Doesn't attract dirt, retards rusting, and made my slides quieter. CW carries it. It's designed for use on RV slides.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 07-10-2014, 05:56 AM   #7
B and B's Avatar
I use rubber slide lube for the rubber seals and plain old axle grease on the rack and gear. Amazing how well it works. The tough part is doing the top seal with slide topers, used a extendable wash pole with a rag.
B and B is online now   Reply With Quote
Old 07-10-2014, 09:04 PM   #8
amxpress's Avatar
Lippert (manufacturer of the slides) states in their manual NOT to use grease on the rack gear.It can attract dirt and grit.
From the manual:
• If the system squeaks or makes any noises it is permissible to apply a coat
of lightweight oil to the drive shaft and roller areas but remove any excess oil
so dirt and debris do not build-up. DO NOT use grease.
Prodigy
Old 07-12-2014, 09:44 PM   #9
BigTJohn's Avatar
Boeshield T9 is the ticket. No messy dirty equipment. Works on every mechanical movement.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 07-13-2014, 03:47 PM   #10
B and B's Avatar
The amount of grease I used is one maybe two fingers for all 4 tracks.
Sent from my Z30 using Forest River Forums mobile app
slide, slide out
