Old 10-12-2012, 04:54 AM   #1
Heat - (SOLVED)
Ok. In the 320rs I am out camping in the cold. Turn the thermostat to heat and both the furnace and the upper air turn on. Not sure if the air is actually turning on but the fan certainly is. Am I doing something wrong here
dkwin1 is offline   Reply With Quote
Old 10-12-2012, 05:41 AM   #2
Check that your "Fan" setting is set to Auto. Typically it is default set to "on" for some reason
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is online now   Reply With Quote
Old 10-12-2012, 05:53 AM   #3
That was it thanks
