We are out on our "real" maiden voyage (a week in the mountains) the electric for our fridge as well as the plug next to the fridge will not work, we are trying to find a breaker or GFI to reset, but are not having any luck. We've flipped the breakers in the breaker panel and still nothing. Any suggestions???
Our 320 gas a GFCI IN THE basement. -feeds the outside outlet and the refer outlet.
Brenda and John
Master Blaster of the Navy
We have an upper and lower outside compartment for the fridge, we checked the lower and there is an outlet but not GFI, we also checked the basement and don't see a GFI outlet there either. We've also verified the GFI breaker is on and not tripped.
Is anything else not working? Is fridge working on gas? Could be a blown fuse. Pull the fuse and check it carefully, it is easy to miss that it's blown.
