Old 12-03-2012, 01:14 PM   #1
rugmanrn's Avatar
High frequency squeal from fuse panel
We have a Columbus 320. We are having a high frequency squeal from fuse panel. It doesnt doesnt sound like a fan and will change pitch when turning on: off lights, water heater etc. any thoughts?
rugmanrn is offline   Reply With Quote
Old 12-03-2012, 01:37 PM   #2
It sounds like your 12 v Power converter may have a problem. I don't have a columbus but the 12 volt supply is likely a switch mode type regulator which uses a power oscilator to generate 12 volts with out the use of a large transformer. I've seen these "partially" fail in other (non-RV) applications where you would hear a sqeal that would vary with change of load.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 12-03-2012, 03:48 PM   #3
Herk7769's Avatar
Failing capacitors can squeal. The cooling fan can also make a screeching noise as well.
HAM CALLSIGN - KC3FFW
