Old 05-22-2014, 08:33 AM   #1
cronek28's Avatar
Thumbs up hitch on back of 5th wheel
Good morning guys,
I'm looking for some advice and or suggestions for buying and installing a 2" receiver on the back of the fifth wheel.
I have two problems since purchasing the 5th wheel my golf cart no longer fits in the back of the truck and my camper doesn't have one of those fancy flip down bike racks some of you guys have. So I'd like to install a hitch to sometimes haul a trailer for the cart and when not be able to put the bike carrier into carry bike
Just looking for some advice I can't find much info it. Will it void warranty? Do they make ones that go past 4x4 bumper? Or is it better to remove stock bumper? Bolt on / weld on? Wiring?
Any thoughts would be appreciated! Thanks!
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline   Reply With Quote
Old 05-22-2014, 08:36 AM   #2
TURBS's Avatar
I wouldn't walk away from this I'd RUN!
TURBS
"Sabre owners united"
ID:	53002   Click image for larger version
ID:	53003   Click image for larger version
Old 05-22-2014, 08:36 AM   #3
SKnight's Avatar
Subscribing as I have the same issue, I need to carry my motorcycle with me. I have a sticker directly saying adding anything will void the warranty on the frame.
Old 05-22-2014, 08:36 AM   #4
TURBS's Avatar
And last but not least
TURBS
Old 05-22-2014, 08:40 AM   #5
cronek28's Avatar
Yeah, that looks unhealthy! That's why I haven't installed the bike carrier. I'm looking/asking about a real class rated receiver mounted to the frame or chassis of the fifth wheel
"Duramax"
Old 05-22-2014, 08:52 AM   #6
cronek28's Avatar
Turbs, is that/was that yours? Wondering what was carried on that bumper, not surprised that bumper made so light it probably only 16ga
"Duramax"
Old 05-22-2014, 08:58 AM   #7
dcheatwood's Avatar
If your fiver is rated for it, check out Idaho tote trailers on the web. I've seen then in cgs but my fiver would fall apart with that load on it.
X2 on all warnings above.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
dcheatwood is online now   Reply With Quote
Old 05-22-2014, 09:09 AM   #8
cronek28's Avatar
Idaho totes look awesome but, $$$$$$$$$$
I'm not sure where to find info if my 5er is rated or not. No one really has answers for me. The dealer said I'm not sure.
I can't image a couple hundred pounds connected to the i-beam frames the trailer is built on would cause to much problems. The frame is strong steel it support the trailer when changing tires or unlevel camp sites but then again what do I know... that's why I'm asking you guys
"Duramax"
Old 05-22-2014, 09:16 AM   #9
abjb's Avatar
Interesting, our SOB 5th wheel was drilled for a hitch, the hitch was a factory option.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 05-22-2014, 09:22 AM   #10
TURBS's Avatar
Not mine no.
But I installed a hitch on my flagstaff quite a few years ago and it didn't end well.
BTW it carried 3 bikes.
If you have a "sheet metal" fabricated I beam frame then I wouldn't even go near this in any way shape or form .
With an actual structural I beam I'd consider a flat rack which mine has from the factory as well as an actual structural I beam.
When I asked Sabre about a hitch I was still told absolutely not!
TURBS
5th wheel, hitch, wheel
