Old 06-14-2013, 07:10 AM   #11
wmtire's Avatar
Originally Posted by BuckeyeChuck View Post
Not all hot water heaters have the electric option. If yours does there should be a switch inside the camper that will allow you to either run it on AC, gas or both. If no switch you PROBABLY have a gas only water heater.
While it is true that you MAY have an inside switch for the electric heating element option, MANY of the RV's equipped with the Suburban water heater have the electric heating element switch on the front of the water heater itself (which is accessed from the outside of the RV). All three of my RV's had the inside switch for the gas portion, and an outside switch for the electric portion. See Turbo's pic in his previous post.
So it boils down to, you may or may not have an inside switch for the electric heating element portion of a Suburban water heater.
This link may help if you have the Suburban water heater in your RV.
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-14-2013, 08:18 AM   #12
tanddc's Avatar
If you do have an outside switch be careful. My switch is "upside down". Up is off and down is on. While you can run a second when the tank has no water in it, the electric is less forgiving and the element will burn up in seconds...or so I hear.
tanddc is offline   Reply With Quote
Old 06-14-2013, 09:08 AM   #13
BuckeyeChuck's Avatar
Reread my post. I think that's what I said. :-)
-BC-
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 06-14-2013, 09:24 AM   #14
wmtire's Avatar
-BC-
BC, you may have still been editing your post, when I posted my clarification. What I quoted was your entire posting at that time. It's all good now.
Old 06-14-2013, 10:15 AM   #15
Probably so....all is good :-)
2013 Sabre 33CKTS
