Old 05-01-2013, 06:52 AM   #1
Hot water tank
Hi, seasonal camper at camp ground with full hook up , what's the best way to operate the hot water tank ie , gas only electric only or both at same time. Thanks Brian
Brian10 is offline   Reply With Quote
Old 05-01-2013, 07:00 AM   #2
Not seasonal, only 3-4 months a year, but we run both at the same time, only time the propane kicks in is when using a lot of hot water. Propane use is minimal.
Old 05-01-2013, 07:07 AM   #3
TURBS's Avatar
Electric for normal use .
propane and electric both for quick recovery during high usages times "showers"
Turbs
Old 05-01-2013, 07:29 AM   #4
Herk7769's Avatar
Depends also on the voltage at your campground.
If your AC seems to "lug" when starting (or a volt meter shows campground voltage 115 VAC or below - USA), then I would turn off the AC portion water heater and use gas. Below 110 VAC; switch the fridge to gas as well.
HAM CALLSIGN - KC3FFW
Old 05-01-2013, 07:59 AM   #5
You, like me, are on a seasonal site and paying for your electricity seperately unlike weekend/daily use campers so either way it's going to cost you. I run mine on both in the morning to get thru the showers. I then leave it on propane until water in tank is hot again and it shuts off then turn propane switch off. I will have enough hot water in my 10 gal tank to get me thru dinner dishes.
Old 05-01-2013, 08:03 AM   #6
wmtire's Avatar
X2
Another thing to always bear in mind is that the 120 volt electric heating element will draw between 9-13 amps average, when it's heating. If you have a 30 amp RV, or hooked to a 30 amp power outlet, this will limit what else you can run in your RV at the same time........as you are limited to 30 amps total.
You may need to turn off the electric heating element, when using other things in conjunction to keep your total amps at 30 or below......so you don't overload/trip the breakers.
Mark Polk has a list of common AC and DC amp usages (as well as a great explanation on the function of converters) at the following link:
http://rvservices.koa.com/rvinformat...d-amp-draw.asp
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-01-2013, 05:04 PM   #7
Thanks to everyone for the advise. Brian
Old 06-13-2013, 10:08 PM   #8
Where is the switch for the hotwater heater to use AC vice Gas? Sorry for the rookie question. Will be going out for just the third time this weekend.
Thanks.
BG
BGG
Camarillo, CA
bikepsych is offline   Reply With Quote
Old 06-13-2013, 11:00 PM   #9
TURBS's Avatar
Thanks.
BG
Out at the water heater normally.
If you have a suburban wh anyway.
Old 06-14-2013, 07:03 AM   #10
BuckeyeChuck's Avatar
Not all hot water heaters have the electric option. If yours does there should be a switch inside the camper that will allow you to either run it on AC, gas or both. If you can not locate it inside look at the tank itself as pictured above. If no switch there either you PROBABLY have a gas only water heater.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
