Old 04-16-2019, 10:41 AM   #1
Hot water Tank won't lite
I have a 2017 180FB TT with a suburban SW6D water hot water heater.
I bought it and it was winterized when I picked it up now after, Dewinterize the hot water tank will not lite.
I have checked all of the fuses and water tank is full when I turn on the switch I get a Dis fault red light that will not go off, The gas tank is full
what else could be the problem I am lost
Grenadier 525 is offline   Reply With Quote
Old 04-16-2019, 10:49 AM   #2
Flybob's Avatar
May be air in the lines. Light the stove and let it run minute or two. Then try again. You should here it click ( from outside). If you do not hear it clicks, then it has gone into safe mode due to not lighting after several tries. Pull the 12V WH fuse for a minute or so and replace it. That should reset it. Now try again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-16-2019, 11:04 AM   #3
If purging the gas line of air by running the stove doesn't clear the problem, check to see if there is actually spark at the igniter. Have someone turn on the heater while you have the cover down and look for actual spark at the tip of the igniter. Sometimes one of natures small critters will have taken up residence in this area (spiders usually) and their web is shorting the spark so it won't ignite the gas. Often a blast of compressed air will clear them out or if no compressed air, clean the area with an old tooth brush being careful to not bend the igniter wire.
Usually the purging will clear this issue but even if gas is getting there, spark is necessary to finish the process of lighting.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 04-16-2019, 11:46 AM   #4
jeff64's Avatar
.. I'd add, If you are hearing a spark, also observe how the igniter is fastened to the burner chamber. That's a system ground. If you see rust, scale etc at that junction, remove the igniter and brush that connection and reassemble. As with any high voltage component be careful with what you go cleaning the igniter itself with... brass wire brush yes, steel wire brush definitely not. Steer clear of the porcelain insulator. If you can read the schematics in the library above, you should determine that the igniter sends a flame presence signal to the board as well as recieving a spark pulse to light up. My guesstimate would be 4-6Kv with that kind of air gap for the spark
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
jeff64 is online now   Reply With Quote
Old 04-16-2019, 02:20 PM   #5
hot water heater
from my experience the the Suburban SW6D hot water heater the first thing to check is the circuit board. They produced a mess of crappie circuit boards that over heat and fail. You can contact them and they will send you a updated replacement (made in China) or order one from Dinosaur Electronics Model UIB S, they are made in the USA and available from Amazon. I have a 24' 2017 EVO TT had the same problem new circuit board fixed it.
frusso70 is offline   Reply With Quote
Old 04-16-2019, 03:25 PM   #6
SailorSam20500's Avatar
Last fall, my tank would not light on propane, no spark for ignition. Since the trailer was going in for service on another issue, I had the dealer look at it. Turns out, the wire connector into the control board had vibrated loose and disconnected. Once plugged in tightly, it works fine. Connection was under a white plastic cover.
Good luck.
Al
Save the Earth. It’s the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 04-16-2019, 03:34 PM   #7
Here is another thread/poster with a similair problem. Turned out to be the circuit board.
Atwood water heater not igniting
Iwritecode is online now   Reply With Quote
Old 04-16-2019, 03:40 PM   #8
Thank you I found the problem someone had all of the water shut off from WH
Old 04-16-2019, 03:44 PM   #9
If you tried turning the heater on with no water in it you may have burned out your heating element.
Old 04-16-2019, 03:47 PM   #10
cavie's Avatar
You need to explain further. In your OP you stated you dewinterized and the tank was full. No water would not have stopped it from lighting on gas. ( I don't believe) No water would have burned out the electric element and you would not have hot water now.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
hot water, lite, tank, water, water tank
