Old 09-07-2014, 09:26 PM   #1
How to merge 2 separate waste hookups, one gray/black water, second gray wate...
Our new Puma 32DBKS has 2 waste water hookups, is there a way to merge them into one? One is from the bathroom (gray/black) the second from the inside and outside kitchens (gray only). Our RV will be on a seasonal site, semi-permanent, with one sewer hookup.
ChiefGeek is offline   Reply With Quote
Old 09-08-2014, 12:02 AM   #2
Rhino hoses makes a Y connector. You run two hoses into one. Bit of a pain, but..
NeilM108 is offline   Reply With Quote
Old 09-08-2014, 07:42 PM   #3
I have the same set-up on my sabre 34 Tbok. I used the valterra hose connector that has the option to hook a garden hose on the 90 degree elbow. From there run a piece of garden hose to your kitchen only grey tank drains and use the 3" to garden hose adapter on the camper. Been doing it this way for 3 years and have had no issues at all
rookiecamper is offline   Reply With Quote
Old 09-08-2014, 10:03 PM   #4
I use the garden hose with a 3" inch to garden hose bayonet adapter on the camper. I then took a regular I then drilled a hole in a Rhino 90 degree elbow at the sewer dump site. I then installed a garden hose male connection with rubber washers allowing me to hook the garden hose to drain into the 3" elbow with the regular 3" hose from the other tanks.
RetCityMan
CityMan is offline   Reply With Quote
Old 09-08-2014, 10:07 PM   #5
B and B's Avatar
Mine are pretty close. I have resisted the flush master one outlet mod. I just move the hose and dump the galley tank after about 4 days when on Full Service. Some day a OC plumb them together mod.
B and B is online now   Reply With Quote
Old 09-09-2014, 09:49 AM   #6
The method I described (not very well) prevents you from moving the hose. It just results in a garden hose draining your dish water and a regular "3" Rhino hose draining your black and other grey tank.
RetCityMan
Old 09-09-2014, 10:02 AM   #7
A permanent fix is to hard plumb them together and add a shutoff valve where they hook together. Takes about 3-4 hrs and $15-$20 and it's finished with no future hassles with y pipes and multiple hoses, etc.
Name:	Rear Connection.jpg
ID:	62475   Click image for larger version
Name:	New Alum Strap to Hold Drain.jpg
ID:	62476   Click image for larger version
Name:	Inside view of Rear Connection.jpg
ID:	62477   Click image for larger version
Name:	Inside view of new connection.jpg
ID:	62478   Click image for larger version
Name:	Galley tank connected with Main Drain.jpg
ID:	62480   Click image for larger version
ID:	62481   Click image for larger version
ID:	62482   Click image for larger version
ID:	62483   Click image for larger version
Name:	Connection of new pipe.jpg
Old 09-09-2014, 10:02 AM   #8
ARLO
I went with Rhinoflex for both with a valterra 3" shutoff at the "y" to segregate the front hose (galley drain).
rlocicero is offline   Reply With Quote
Old 09-09-2014, 10:04 AM   #9
RetCityMan
Can you get us a picture of your setup please?
harderd is offline   Reply With Quote
Old 09-09-2014, 02:02 PM   #10
CBergstrom's Avatar
OC, how did you tie into the elbow coming off the bottom of the tank? I've thought about doing the same thing to our Sabre 34TBOK as a way to expand our grey water capacity. We always find that the bathroom grey water always fills up and our other two grey tanks never get more than half full.
I've used two sewer hoses, a Y, and a cap to transfer in pinch but then you have two hoses full of grey water to deal with.....
CBergstrom is offline   Reply With Quote
black, black water, water
