05-13-2013, 07:22 PM
#61
Originally Posted by clancythecamper
I saw a front bike holder on an A line camper this weekend and thought it was the greatest idea!
My main wish for the 233S would probably be drawer space, maybe a built in cabinet next to fridge on the left with drawers? There is a hook up there for a tv but you could probably adjust that so that you could use it for a tv or for coffee maker, toaster, etc.
I also wish the soap/shampoo holders actually held something. Maybe have something with a bar to hold it in place?
Thank you for your request It's nice to be heard
Clancy, the OP, a Columbus rep, was asking for ideas for Columbus 5th wheels, not the Roo line, if you didn't know.
05-13-2013, 08:56 PM
#62
No, didn't realize that. Thx
05-13-2013, 09:16 PM
#63
On the 365RL, the black/grey water discharge pipe is too low to the ground. If it could be raised to same height as the kitchen sink water discharge pipe would be big improvement. Also sliding door in bedroom needs cushion between door and wall as there is scratching occurring to the bottom section of the door due to opening and closing door. Have better quality control at factory before units depart would be a big plus.
2013 Columbus 365RL
It's All Good!!!
05-14-2013, 05:37 AM
#64
Commercial Member
How about a standard wet bolt kit for the suspension?
Or, at least the lifetime bushings in the springs....most people never check these, and they do wear out after a year or two. The factory vinyl inserts are crap, either worn through or crack and fall out. Use the bronze inserts and wet bolts so we can grease them.
Best upgrade I ever did on the Wildcat....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
05-17-2013, 01:34 PM
#65
We have a 2013 340rk and are pretty happy so far. Few things I'd like changed though.
Sky light in the shower should be moved so it is directly over the shower head area where a person stands. I'm 6'3" so the few inches would be nice.
Several of the cupboard doors hit things when opened. I installed clear stoppers to protect the finish.
The temp sensor for the electric fireplace is inside the cabinet and there is a heat duct in said cabinet. When the furnace runs the fireplace shuts off. I rerouted the temp sensor out into the room.
The light switches could be located in a more user friendly spot than in a low cabinet and labeled.
Heat vents with adjusters on them to balance out the air flow. Gets blazing hot in the bathroom, bedroom, basment and just slightly warm air finds its way out of the kitchen vent
Doors to the propane storage area large enough to accept 30 # cylinders.
Super nice big kitchen but a larger range/oven would be nice.
Electrical outlets on both sides of the bed and the light switch for the bedroom on the inside of the bedroom instead of in the hall.
05-17-2013, 04:42 PM
#66
After spending a week in our 320RS, I found one thing I would change. The location of the overhead LED light in the bathroom. When standing in front of the mirror to shave, the light is shining behind me which makes it difficult to see my face to shave, etc. Relocate the light so it is closer to the medicine cabinet.
I also think a Blu Ray player should be used instead of the DVD player.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
05-18-2013, 07:10 AM
#67
Question for the Palomino company representative...
There are many great ideas /recommendations I see people posting. How often are these reviewed and how long does it take before any of them are implemented?
05-18-2013, 08:13 AM
#68
Living area floor, remote, & bike rack information
We picked up our 320RS last week. I have three suggestions so far:
1. The living area floor surface is very prone to denting from the movable island and other things. Use a harder pad under the flooring to prevent or reduce the dent issue.
2. Provide better instruction manuals for the accessories, e.g. the bike rack. We visited several dealers and not one could explain how to mount bicycles on the bike rack. There is no information in any of the user material that I can find. I've found a few ideas on this forum, but someone who designed the rack should have an idea as to how to use it.
3. Provide a remote for the slide out and awning operation.
4. Provide more customer instructional videos on your website.
All in all, this is a great RV.
Thanks!
05-18-2013, 08:14 AM
#69
Thanks!
The bike rack does not hold a standard 26 inch bike!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
05-18-2013, 08:53 AM
#70
We don't have a Columbus so don't know if applies, but our fifth wheeler LR-Dining slide out has two overhead skylights....when looking at rvs thought we would like them but they let an extreme amount of heat in from the sun on a hot summer day. Now I would not want them if repurchasing new camper.
papamcgown
McCune, KS
2010 Dodge Ram QC 2500 HD w/Cummins Diesel
2013 Salem Hemisphere Lite 346 QBUD
05-18-2013, 08:01 PM
#71
Here is a simple one that would REALLY help a lot. Put another water pump switch in the bathroom.
And put a valve on the city water connection that allows me to fill the on board water tank without having to connect another hose. Just be able to turn the switch to fill one or the other.
05-18-2013, 09:59 PM
#72
The kitchen table is a (bad) joke. The three piece design is just bad; on my unit, the third piece(leaf) is simply broken because of the press board used for the rails, and the two pieces on the main table to not match up correctly, and are not even the same thickness.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
#73
The latches that hold the doors open; who thought making them out of plastic was a good idea? Really?
2014 Columbus 320RS
05-19-2013, 07:45 AM
#74
Commercial Member
Again, there is a reason.
Come on our lot and look at 300 RV's, and find some without a plastic door holder.
There are two options....Winnebago uses an aluminum bar that you put in and take out of clamps, and the hydraulic struts that are typically used when the awning arms are mounted behind the doors.
Only 2 options for cargo doors as well.....hydraulic struts, or the magnetc latches that Prime Time uses (which, we have found don't do very well in wind either)
These aren't aluminum skinned horse trailers, they are thin fiberglass sided, and you would much rather fix a broken plastic t bar than patch and repair holes in the fiberglass skin when the screws are ripped out of the sidewall.
Steve and Vicki
2 kids
(Tweaked!!)
05-19-2013, 08:05 AM
#75
O.K., I'll accept the plastic latches.
2014 Columbus 320RS
05-20-2013, 07:56 PM
#76
How about clearly and correctly labeling the water hose connections in the wet bay
05-20-2013, 08:37 PM
#77
All of mine are clearly labeled!!
Scott & Vicki
2021 4 reserved
05-20-2013, 08:41 PM
#78
Mine were less than clear and hardly correct on mine they have the black tank flush labeled as fresh water
