Old 05-18-2013, 08:01 PM   #71
Here is a simple one that would REALLY help a lot. Put another water pump switch in the bathroom.
And put a valve on the city water connection that allows me to fill the on board water tank without having to connect another hose. Just be able to turn the switch to fill one or the other.
SargeW is offline   Reply With Quote
Old 05-18-2013, 09:59 PM   #72
treaves's Avatar
The kitchen table is a (bad) joke. The three piece design is just bad; on my unit, the third piece(leaf) is simply broken because of the press board used for the rails, and the two pieces on the main table to not match up correctly, and are not even the same thickness.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 05-18-2013, 09:59 PM   #73
treaves's Avatar
The latches that hold the doors open; who thought making them out of plastic was a good idea? Really?
2014 Columbus 320RS
Old 05-19-2013, 07:45 AM   #74
Commercial Member
huntr70's Avatar
Again, there is a reason.
Come on our lot and look at 300 RV's, and find some without a plastic door holder.
There are two options....Winnebago uses an aluminum bar that you put in and take out of clamps, and the hydraulic struts that are typically used when the awning arms are mounted behind the doors.
Only 2 options for cargo doors as well.....hydraulic struts, or the magnetc latches that Prime Time uses (which, we have found don't do very well in wind either)
These aren't aluminum skinned horse trailers, they are thin fiberglass sided, and you would much rather fix a broken plastic t bar than patch and repair holes in the fiberglass skin when the screws are ripped out of the sidewall.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 05-19-2013, 08:05 AM   #75
treaves's Avatar
O.K., I'll accept the plastic latches.
2014 Columbus 320RS
Old 05-20-2013, 07:56 PM   #76
iceblaze580's Avatar
How about clearly and correctly labeling the water hose connections in the wet bay
iceblaze580 is offline   Reply With Quote
Old 05-20-2013, 08:37 PM   #77
SYE
SYE's Avatar
All of mine are clearly labeled!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 05-20-2013, 08:41 PM   #78
Mine were less than clear and hardly correct on mine they have the black tank flush labeled as fresh water
