Old 05-12-2016, 08:34 PM   #1
Insert dvd, can hear it, but can't see it on tv
Need help. Have 2016 Puma XLE 30DBSC and just installed Emerson 32" tv in living room. Have a Boss Audio am/fm/cd/dvd player installed right underneath tv mount. Can insert dvd and hear the sound but not seeing it on tv screen. Checked every cable known to check. What am I missing???????
Pharmgal2211 is offline   Reply With Quote
Old 05-12-2016, 08:46 PM   #2
Oakman's Avatar
Did you go into the television's menu and change the input?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 05-12-2016, 08:48 PM   #3
I changed it from regular tv to video. On our tv, after you scroll through all digital channels, HDMI 1 appears, then HDMI 2 appears then COMPONENT appears and then VIDEO appears with a blank screen.
Old 05-12-2016, 08:52 PM   #4
Flybob's Avatar
How did you connect the DVD player to the TV ( Cable type?).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2016, 08:54 PM   #5
It's not a basic dvd player. It's a wall mounted am/fm radio that's plays dvds. I have the 3 cables that run from it plugged directly into the back of the tv. Have sound, just no picture.
Old 05-12-2016, 08:55 PM   #6
I feel like I am missing a video cable somewhere or I need to go buy one maybe????
Old 05-12-2016, 08:57 PM   #7
Oakman's Avatar
Did you stop at COMPONENT to see if the picture came in? Did you stop at the two HDMI inputs to see if the picture came in?
Bob and Joyce
ATU Local 788
Old 05-12-2016, 08:58 PM   #8
Yes and all 3 are blank screens
Old 05-12-2016, 08:59 PM   #9
I'm just gonna take it back to the rv center where I bought it and have one of their technicians look at it.
Old 05-12-2016, 09:15 PM   #10
tv dvd hookup
I'm no expert, but along with the usual RCA cables, red and white, for stereo sound, there should be a yellow for video. OR: there is an HDMI port on the player, and an HDMI port on the TV. OR: there is a digital video out, which is an ORANGE hubbed RCA-ish looking plug, that goes into an ORANGE port on the TV. It is a special digital cable and regular RCA jacks won't work on it.
Most often it is a combo of these cables that is your final solution.
A trip to the vender is often the only solution, since the manufacturer just throws these things in there, and no telling HOW they are hooked up.
I have owned 5 different rigs, and NONE were hooked up right.
As noted above, when playing, scan the input sources, and stop at each one for a few moments to see if the signal is coming through. It might be "Video" "Game"
"HDMI" 1 or 2, or someother combo. Check your manuals for player and TV, too.
hankpac is offline   Reply With Quote
dvd
