Old 03-28-2013, 12:06 PM   #41
JT Strongarm
I just bought the JT Strongarms and had them installed on my Columbus 2013 320RS fifthwheel. I took delivery of the Columbus Sep 2012. I bought the JT Strongarms from Camping World. Free delevery with Good Sams card. $281.99 plus tax (TN) ran me around $320.00 (online). I was having warranty work and had them shipped to the dealer. The dealer installed them for me and as worked out before only charged an hours work. My unit did not have the mounts already installed and the dealer had to install everything. The dealer stated it took him 6 hrs to install. I have read several post where the 2013 has the mounts pre-installed but mine did not. I have them installed on my front jacks (4 places) and my rear electric jacks (2 places)
Bottom line: they do make a big difference. Do they stop all movement? NO. I also use a tripod and wheel chocks that tighten down between the tires. Nothing will prevent all movement, however they are worth the money. They set up and tear down by a T-handle adjustment in less than a minute for the whole setup and are permanently attached to the unit and the jacks.
This was my first trip with them but I am very impressed so far. It looks like the only maint is to shoot some WD40 on the T handle threads every now and then.
Would I recomend them? Yes
khamis is offline   Reply With Quote
Old 03-28-2013, 02:32 PM   #42
amxpress's Avatar
What wheel chocks are you using between the tires?
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 03-29-2013, 11:40 AM   #43
I am using "X-Chock Tire Locking Chock" which I also bought from Camping World. 2 in a box for $99. I have seen them in use by several folks and they seem to be happy with them. I did not do any research on chocks. I just happened to be at the store and saw them. They are easy to install and remove. I have 2 slides so I make sure I install them before I slide the slides out and remove them once the slides are back in. This is for ease of installation and removal.
Old 03-29-2013, 02:12 PM   #44
treaves's Avatar
I'd be worried about putting that kind of lateral stress on the axels.
treaves is offline   Reply With Quote
Old 03-29-2013, 02:34 PM   #45
Don't think they put as much lateral stress on the axles as just going down the highway. All is does is stop the wheels from turning. Think of the stress put on the axles when you brake. Much more severe.
Old 03-29-2013, 02:40 PM   #46
TURBS's Avatar
SIX HOURS ? To put on strong arms?
Man that's a gig I need to get into!
It can be done in half that time easy !
8 arms I'm assuming?
Old 03-29-2013, 02:44 PM   #47
You and me both Turbs, only took me 10 hrs to design, build, paint and install 8 on my 08Flagstaff831RLSS.
Old 03-29-2013, 02:54 PM   #48
TURBS's Avatar
Lol if anyone wants them installed in goshen i'll surely charge 6 hours and most definitely be drinking a Guinness in 2.5!
Old 03-29-2013, 03:03 PM   #49
Denver, CO
garbonz's Avatar
Maybe they were very careful. I kinda like my Winfield's, as you can adjust them by just turning the bars. Seems like that is better than just tightening a t handle or a big thumb screw. IMO.
2017 Fuse 23T
Old 03-29-2013, 03:40 PM   #50
treaves's Avatar
Your statement is not accurate. When you brake, you are applying pressure on the drums, pulling them equally (top & bottom) towards the axle. This will cause a twisting stress around the axle's center. The system is designed for this.The X type chalks are forcing the wheels apart from each other, putting (potentially a good deal) of stress on components that were not designed for that type of stress. Whether the stress is significant or not is a different question.
Old 03-29-2013, 04:01 PM   #51
... When you brake, you are applying pressure on the drums, pulling them equally (top & bottom) towards the axle...
The load on the drums is not an issue.
The load or stress during braking is to bend the spindle to the rear due to tire contact with the road and the forward motion (inertia) of the frame/trailer. The difference in the x chocks is the front tire is being pushed forward and the rear tire/spindle to the rear (the same direction as when braking). So the only difference is the forward load on the front spindle.
In reality, the tires deflect very easy, easily absorbing what little force is being exerted on the spindles from the x chocks. The load is insignificant.
Old 03-29-2013, 05:37 PM   #52
SYE
SYE's Avatar
I will let you know how long it takes to to install them as soon as I get my 5er back and a nice day to install them.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 03-29-2013, 05:43 PM   #53
Save them for Goshen, Turbs and I will install them and only charge 2 hrs labor (ea).
Old 03-29-2013, 05:51 PM   #54
SYE
SYE's Avatar
I hate paying someone for something I can do myself. I am guessing 45 minutes!!
Scott & Vicki
2021 4 reserved
Old 03-29-2013, 07:52 PM   #55
Camping Crazy
columbusfan325's Avatar
I have the Columbus 325RL and the brackets were installed already. Literally took me 1/2 hour to install the JT Armstrong and they work great.
Brian & Kathy
2012 GMC Sierra 2500HD
6L Gas 4x4
2013 Columbus 325RL
columbusfan325 is offline   Reply With Quote
Old 03-29-2013, 07:54 PM   #56
BBBBBut Turbs needs beer money and I need coffee money and we both need gas money. Have a heart and share your wealth!
Old 03-29-2013, 08:33 PM   #57
SYE
SYE's Avatar
I'll give Turbs a beer and stop by in the morning and I'll give you s coffee, no charge, when we are in Goshen. I was actually in Goshen today
Scott & Vicki
2021 4 reserved
Old 03-29-2013, 08:43 PM   #58
TURBS's Avatar
I resemble that remark!
I do need beer money........
And gas money.....
Old 03-29-2013, 08:52 PM   #59
SYE
SYE's Avatar
And gas money.....
OK because I live in Michigan and you need beer money, I'll give you a beer and let you keep the bottle, and there is your gas money because the bottles have a 10 cent deposit on them. See what are friends for!!!
Scott & Vicki
2021 4 reserved
Old 03-29-2013, 08:53 PM   #60
TURBS's Avatar
Thanks sy-ism
