Old 10-01-2012, 08:46 PM   #1
Columbus 302 rs
JT's Strong Arm Jack Stabilizers
Finished installing the JT's Strong Arm Jack Stabilizers on our Columbus 320rs and it's made a big difference even when the washer and dryer are operating.
Easy to install and a great value.
I'll need to see how they work after a number of trips raising and lowering the stablilizing jacks to make a final recommendation.
TheEdge is offline   Reply With Quote
Old 10-02-2012, 05:34 AM   #2
I'm looking at buying a 320rs and it looks like the mounting brackets are already installed.
Did you have to install the brackets or are they a standard feature?
Pa-cj5 is offline   Reply With Quote
Old 10-02-2012, 06:24 AM   #3
TURBS's Avatar
Not sure brackets are pre installed.
Pics ?
Turbs
Old 10-02-2012, 08:40 AM   #4
Did u install 3 sets. (2 in front; 1 in rear?). Was it hard to get to bare metal of the frame or did you have to drill through the wrap around plastic body molding.
I konw. A lot of questions. But I was just looking at these yetserday.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 10-02-2012, 08:46 AM   #5
Make your own brackets and adapt these:S Line Ratcheting Pickup or SUV Bar 60in. - 72in. Adjustment | Cargo Bars| Northern Tool + Equipment. I would use 2 in back and 2 in front.
Old 10-02-2012, 09:47 AM   #6
Factory Rep
Columbus now puts the brackets on the frame for JT Strong arm in case acust. Wishes to install at a later date
I don't believe any other Brand does this
Chris
Christopher Columbus is offline   Reply With Quote
Old 10-02-2012, 10:09 AM   #7
hd riders's Avatar
We ordered the Strong Arms on our 320 also the 6 point leveling is this over kill???? or work good this way.
hd riders is offline   Reply With Quote
Old 10-02-2012, 10:29 AM   #8
Factory Rep
The JT system is to give you side to side stabilization.
The level up is just to level the unit
Not overkill to have both. I would have both
Chris
Old 10-02-2012, 10:38 AM   #9
hd riders's Avatar
Thanks Chris for you quick answer as this is our first 5th wheel we need all the help we can get, ours should be here in about 7-9 weeks.
Old 10-02-2012, 03:23 PM   #10
Columbus 302 rs
Yes, what made the job so easy was the preinstallation of the brackets. If our salesman had told us about the system we would have ordered it with the unit, but as it was it was an easy job. There are four struts at the front and two struts at the rear.
Old 10-02-2012, 08:00 PM   #11
Thanks for the quick answers, looks like it will be an easy install with no drilling required.
Old 10-02-2012, 08:09 PM   #12
Columbus 302 rs
Actually you do need to drill the front lift holes to a larger diameter 1/2 inch.
Enlarge one set of holes on each leg one hole up from foot.
Old 10-02-2012, 08:29 PM   #13
Thanks, what is the price of the kit?
Old 10-03-2012, 11:50 AM   #14
Mike Zeto
Chris I have a 2013 320rs purchased in june and do not have the brackets can those be sent and be added to the trailer.
mzetp is offline   Reply With Quote
Old 10-03-2012, 12:15 PM   #15
$350.00 and up.
Old 10-03-2012, 12:28 PM   #16
Very good info. i ordered my 320RS with the 6 point and the strong arm assembly and was wondering how many struts i was going to end up with. I believe my unit will be in this week..... i'll try to post some pics for everyone.
Paul & Beth
Sandusky, Ohio
2013 Columbus 320RS
2009 Silverado 2500HD
drinkh20 is offline   Reply With Quote
Old 10-03-2012, 12:39 PM   #17
Columbus 302 rs
The brackets come with the kit and instructions for measuring there placement is also included. Very good instruction manual with illustrations.
I paid about $320.00 for the entire setup but threw away the brackets since mine
were already installed.
Old 10-22-2012, 09:57 PM   #18
Mike Zeto
When installing the front stabilizers do they clear the battery box, and how are the rear ones attached..
Old 10-23-2012, 09:04 AM   #19
The front stabilizers have two on each one of the front landing legs. The rear has just one on each landing gear legs.
On the front, they are coupled together at the base of the foot and extend up to the frame and yes it clears the battery box. The rears are the same way, bolted at the base and extend to the rear up to the frame. This set up is very nice with the six point system. The unit is really firm and im not going to use my pin box tri pod anymore.
Paul & Beth
Sandusky, Ohio
2013 Columbus 320RS
Old 10-23-2012, 03:06 PM   #20
hd riders's Avatar
drinkh20 did your 320Rs get to dealer yet? ours got in Sat. and we went and looked at it this Monday all looks good will do PDI in a week as it got here sooner then the dealer thought. We also got the 6 point leveling and the strong arms.
