Old 05-17-2013, 06:02 PM   #1
treaves's Avatar
Just got it home - with break trouble
About 90 miles from the dealership, my trailer brakes went out. My beak controller said 'check trailer brake wiring'. I pulled over, fiddled with everything, and no breaks. I made it home, and about 10 miles from home, they started working again. I'm thinking loose wire, but, I'm not a mechanic.
This has me worried, with my first trip next Wednesday.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 05-17-2013, 06:10 PM   #2
clancythecamper's Avatar
Ugh!!!! Do you know someone close to home that can check it for you?
clancythecamper is offline   Reply With Quote
Old 05-17-2013, 06:41 PM   #3
B47
Did the brakes freeze up on you while traveling (you didn't say) ? If not , the first things I suggest checking would be your fuses, wires, TV cable connection ( both ends ).
Old 05-17-2013, 07:16 PM   #4
I would methodically go through it this weekend using the following troubleshooting....
TV: Check the connector you plug the trailer umbilical into... Look for rust or corrosion.
Camper: Ours has a terminal box up inside the pin box area. Take the cover off and check connectors/wires.
Axles: Check connectors and wires around each wheel...
Move your truck in close so as to be able to plug in the cord... and watch your brake controller. Wiggle wires and connectors in all of the above locations and watch for changes on the brake controller.
Nice rig - hope you get it straight and have a great holiday weekend.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-17-2013, 08:28 PM   #5
treaves's Avatar
No, the brakes didn't freeze, the didn't respond, and the brake controller could not detect them. And then they worked as I arrived home, so it's intermittent.
The truck is only a couple months old. The connector does have greace in it; I'd assume electric-compatable.
I'll go through it as recommended. I hope it is something obvious. The big issue will be trying to do all of this myself, as I have no one to help me this weekend. So I'll do what I can.
2014 Columbus 320RS
Old 05-17-2013, 08:42 PM   #6
B47
Some electrical problems are easily detected e.g. Broken wire, loose connection and others are not. Without going out on a limb here, I would say your problem is something simple - hope I am correct.
Does your TV brake controller respond to different settings when you try to adjust it up or down?
Start from the front ( under hood fuses) and go back from there. I am assuming you are using a VOM when checking for power at the plugs.
Let us know what you find and good luck.
Old 05-18-2013, 08:43 PM   #7
It does sound like a loose ground wire somewhere in the string.
SargeW is offline   Reply With Quote
Old 05-18-2013, 08:59 PM   #8
Phat Phrog Stunt Crew
awwall's Avatar
It should be simple. With the brakes, all you have to deal with is 1 wire and a ground. Get a plug wiring diagram (do a search on here there are several) and a meter and go to work. I would wash out the grease and replace with a light lubricant. I use WD40 as a water repellent.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-18-2013, 09:00 PM   #9
That would be the first thing I would check as well, and the problem is likely with the camper, not the truck.
It would be a lot easier if you had someone to watch the controller while you fiddle with the wires.
And that is a really nice rig, you sure don't want to be going anywhere without dependable brakes.
Good luck.
bakken is offline   Reply With Quote
Old 05-18-2013, 09:47 PM   #10
Earth Station's Avatar
Call your dealer.... a 2014 should be under bumper to cap warranty!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
