Old 03-23-2015, 12:45 PM   #11
Originally Posted by SULTINI View Post
To bad your hitch didn't have a height adjustment on it.
Can't go any lower on the hitch. I have a pullrite autoslider and the only adjustment is the low profile feet which I already have so this was my next option.
mikeysotp is offline   Reply With Quote
Old 03-23-2015, 12:47 PM   #12
Originally Posted by tbritt View Post
I took an inch and a half off from where the flat part of the cover is at the pin plate, tapered all the way back and rounded the ends in the back. used a drammel tool work slow and smooth...looks good and most people thinks it came that way....
Awesome, thank you so much. Now I can go at it knowing it is possible and I love using my dremel. lol
Old 03-23-2015, 06:59 PM   #13
I had a similar problem when I replaced the stock pin box with a MORryde rubber pin box. I was able to re attach the cover a few inches forward but had to drill some new holes. Also I did do a little trimming on the front edge to avoid contact with the hitch plate.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 03-25-2015, 07:37 PM   #14
5verdriver's Avatar
When we bought our QBOK, we had the PullRite installed too. Because of the 'capture plate' on the pin box the plastic cover won't fit without a little Dremel action also. But, I still haven't found time to do it.
2013 Palomino Sabre 36 QBOK-7
2012 Ford F-350 SRW 6.7 CrewCab ShortBed
PullRite SuperSlide 18k IS Rails
2006 HarleyDavidson RoadKing Classic
5verdriver is offline   Reply With Quote
cover
