Old 08-19-2013, 09:28 PM   #21
SYE
SYE's Avatar
Originally Posted by f1100turbo View Post
If I get one fabricated and it works proper you know I'll make sye one!
Too cool!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 08-19-2013, 11:42 PM   #22
SYE
SYE's Avatar
Hey Turbs, I have also found this one it is a bit different.
LANDING LEG FOOT
Scott & Vicki
Old 08-20-2013, 05:13 PM   #23
Landing gear
Very seldom will you be on level ground or concrete so really you should not worry about it. Even if you are on a concrete pad there is a very good chance that the concrete from where the axles are set to where the landing gear goes down will not be the same. What you are trying to do when you put down the landing gear is to have each bottom plate hit a solid supporting surface at the same time. This is accomplished by pulling the pin out of each leg and letting them hit the ground( wood pad). Now lift up each pad untill the pin goes into a hole. Lower your landing gear until the longest leg hits bottom (the ground, a board ). The other leg should be shimmed until the the gap is filled. I carry with me 6 pcs of 1/4" plwood 12"x12". Does the trick ever time.
Bob
bclantz is offline   Reply With Quote
