06-16-2018, 08:38 PM
LCI auto level fuse
I've looked everywhere I can think of I can't find a fuse that runs my auto level screen. Was working one min the nothing black screen no power.
Palimino Columbus 365RL
I've read that the fuse would blow if over extending the jacks I'm in a very uneven spot and am having trouble getting level and have ran out of Jack a few times that what makes me think it's the fuse. But I can find any fuses in or around the leveling system wires
06-16-2018, 08:46 PM
Might be one with the unit under the trl I have a box in my storage compartment next to the external face panels also I have overextended not blown fuse usually says something about bore stroke hope this helps
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
06-16-2018, 08:51 PM
Looked all over storage compartment no luck I'll go look under unit do you mean under the trailer or under auto level panel I've looked under auto level panel amd nothing. I'll have to strip all the under skirting to look under the trailer
06-16-2018, 08:52 PM
My fuse is in the slam bag compartment in the front of the camper next to the propane storage.
2018 Ford F-450 DRW
2017 Sandpiper 379FLOK
06-16-2018, 08:55 PM
Have you look next to the hydraulic fluid reservoir?
2018 Ford F-450 DRW
06-16-2018, 08:56 PM
It’s in storage compartment behind the panel not sure if fuse is in it but I would suspect
06-16-2018, 09:18 PM
Go to this link, post 16. Look at bottom pic. There are micro resettable breakers on the side of what looks like a buss bar...
Read the post and it will tell you where to look...
http://www.forestriverforums.com/for...ml#post1545759
06-16-2018, 09:40 PM
I have followed and traced every site in the system no fuses at all in the system.
I do have what looks like a buss bar like dalford mentioned but I don't see any way to reset anything I'll look again in the morning.
My last ditch plan before replacing the whole system ( that cant be cheap)
Next plan replace battery hoping that battery is not holding enough voltage.
06-16-2018, 09:45 PM
Tore the whole storage compartment apart removed any removable panels and nothing.
06-16-2018, 09:47 PM
I am with out a doubt almost sure there is no fuse in any of this system wiring.
06-16-2018, 09:55 PM
Ok, if you found what looks like a buss bar look on the side of it. There are small buttons to push to reset the breaker....
06-16-2018, 10:01 PM
Look closely at this pic.. the reset button are circled and pointed to.
06-16-2018, 10:08 PM
No buttons on mine
06-16-2018, 10:09 PM
Another pic
06-17-2018, 12:32 PM
Take a look in the storage compartment where your hydrolic fluid tank is. There is an inline fuse there that powers the control head. Its encased in a little black fuse holder. Should have a full sized blue automotive fuse in it.
06-18-2018, 12:57 PM
Mdougcarter did you check under the red plastic covers. I just felt on the side of mind & you could feel the button.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
