Old 10-26-2012, 08:09 PM   #11
We have a 2013 34 tbok with the same shower and have experienced the same issues as well. It seems to be worse if we are leaning toward the shower doors. I am gonna try to add some more caulking to help. In the mean time we have just been using a towel or rug to catch the water for now.
rookiecamper is offline   Reply With Quote
Old 10-27-2012, 06:44 AM   #12
ret2006's Avatar
We have a 2012 31-RETS with the same type leak on the left of the shower, the panel facing the sink cabinet. Water looked like it was coming from under the glass frame where it meet the plastic base. I added a bead of silicone but it will still leak if the shower head is directed against the left glass panel, so we are just careful not to aim it that direction. I may try adding some more silicone to the sides but for now I am not going to worry about it.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-27-2012, 08:33 AM   #13
jsk
We also have water that escapes in the same place. I added some silicone but no help. I am thinkikng of adding and modifying the drain holes in the base that the doors slide in. It always leaks on sink end of the door and never the other end. We also have a minimum amount of flex in the shower floor but not around the drain. Please pass along any findings and learnings.
2012 F-350 SRW 6.7
2012 Sabre 34-REQS
jsk is offline   Reply With Quote
