Old 09-15-2019, 11:24 AM   #1
Lightbulb LED Step Lights Not Working
I just purchased a 2015 Palomino SolAire 163X and so far so good! I have a question about my LED stair lights though. The wiring is broken about 5 inches from the end of the LED strip. There is no indication of where they come from though. There is a plastic wire protective tube coming out of a hole in the frame somewhat near that broken wire. I don't see the other end of the broken wire coming from there. Can someone enlighten me as to where these wires should go? Is there a switch of some kind that interrupts the circuit when the stairs are in the stowed position? Was there a switch that activates when the stairs are down? Any and all comments would be appreciated! Thank you!
PJs Dad is offline   Reply With Quote
led, light
