Old 09-20-2014, 10:35 PM   #1
miatared's Avatar
Lippert SBS maintenance ?
I have a 2010 Sabre 31REDS and want to repack the bearings. It has the LCI SBS hubs.
What are my options? I read in another section they are not serviceable ... Is this the case. If so, was Lippert thinking!
Thanks.
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 09-21-2014, 07:25 AM   #2
H2oski
I looked at your brochure and it says you have a Super Lube axle / bearings not the sealed bearings.
I looked a LCI and a sealed bearing hub is 500 dollars, that's crazy.
Can you see a Part number on the axle and then check on line to find out what type you have.
Check out this web site and compare it to your hubs.
SuperLube Trailer Wheel Hub/Spindles Owners Manual
Someone else will chime in pretty soon.
Good Luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 09-21-2014, 04:34 PM   #3
miatared's Avatar
I'll have a look at the model number, but SBS decals are on both sides, above the axles, pretty sure they are.... I read in a post that some folks got free new axles - with lube able hubs - sent to them upon calling LCI. I am not the original buyer and wonder what I will do
Denis & Diane
* Happy Campers *
maintenance
