Old 10-20-2014, 06:23 AM   #1
BuckeyeChuck's Avatar
low point drains using antifreeze
I did not open then recap the low point drains prior to pumping antifreeze thru the system. Should I have?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 10-20-2014, 06:27 AM   #2
Do you know for a fact that you didn't (Push) water to the (Dead End) of the Low water drains? Youroo!!
Old 10-20-2014, 06:50 AM   #3
I did not remove the caps
2013 Sabre 33CKTS
Old 10-20-2014, 06:57 AM   #4
Slowly unscrew caps and see if (Pink) flows out! Youroo!!
Old 10-20-2014, 08:49 AM   #5
I did just that. It came out pink. Guess I'm good. Thanks for the replies.
2013 Sabre 33CKTS
antifreeze, drain
