Old 02-25-2015, 09:56 AM   #21
BuckeyeChuck's Avatar
The LT vs ST debate is almost like the 1/2 towing light weight 5er debate.
No clear consensus and a LOT of personal opinions
I believe I saw a post from WMTire (Site team and tire professional that outlined the whys and why nots of LT & ST tires)
But I remember a quote from a tire seminar I went to last year: "Special trailer tires are designed with a thicker side wall than passenger vehicle tires because they need to handle more vertical load."
Also, I have a pretty good RV101 Article. here is the link:
Trailer Towing – ST Tires vs. LT Tires | RV 101® your education source for RV information.
After reading the above I'm staying with ST tires. Question is: Where does one get each tire weight weighed?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 02-25-2015, 09:59 AM   #22
HVSBamaBob....good info. thanks.
2013 Sabre 33CKTS
Old 02-25-2015, 06:18 PM   #23
BamaBob's Avatar
Originally Posted by KyDan View Post
Note- we think you may be confusing a member named tireman with
site team volunteer moderator extraordinaire wmtire.
Ahhhh Maybe so Dan - if so, my Apologies for mixing things up!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 02-25-2015, 06:21 PM   #24
BamaBob's Avatar
By Chance are you going to the Goshen Rally Chuck? If so, they have a "weight police" vendor that, for $60 will do a comprehensive weight analysis of your complete rig and TV
Old 02-26-2015, 09:13 AM   #25
extremebike's Avatar
To answer your question I went with Michelin XPS Ribs. The 235R85 16 come in two sizes 30.7 inch diameter and 32 inch. The 32 is likely too large. I researched Yokohama and Goodyear in addition to Michelin.
On the Michelin and Goodyear sites these tire are rated to all position tires.
The Michelins have been on for three years now and no issues. Way better than the Trail Express doughnuts that came with the trailer. I was lucky and saw bulges before a blowout.
BTW go with bead balancing, its a few bucks more but you don't have to worry about losing a weight.
Good Luck.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 02-26-2015, 08:49 PM   #26
Cobrafan's Avatar
Good Luck.
This is spot on. Balance the truck with beads as well.
2013 Columbus 365 RL
2009 Ford F350 Super Duty Dually
Cobrafan is offline   Reply With Quote
Old 02-26-2015, 08:50 PM   #27
I wasn't that impressed with the article. The part about don't expect the same life expectancy from ST tires. Why not? If an ST tire is designed to carry a certain load and handle the unique aspects of trailering, then it should have a tire life equal to an LT tire used on a truck. When I first started RVing, I recall the guideline for ST tires was 7 yrs. I owned my 1st fiver for 7 yrs and sold it with the original ST tires. Today, all the ST manufacturers say replacement may be necessary after just 3 yrs. What has changed?
Then the part about tires degrading from the inside out and the affects of over/under inflation. Why would that apply only to ST tires? Prior to factory TPMS, most of us probably had the wrong inflation for our LT tires as well. And as far as abuse, my truck and fiver both pretty much hit the same quantity of potholes and curbs while towing but the truck running solo also hits many more. The only time the fiver tires see more stress is with sharp jack-knifing manuvers, which I rarely do.
Finally, the topic of load capacity, neither a 3400 lb capacity ST tire or a 3042 lb capacity LT tire will work on a 7K axle, yet both will work on a 6K axle and there are no other axle capacities in between, so switching to an LT tire may not mean giving up any usable capacity. I switched from factory supplied 3400 lb capacity ST tires a few yrs ago to 3042 lb LTs, BFG Commercial T/A's. Both are overkill since my axles are just rated for 5200 lbs. Prior to my decision, at a multi brand rally, I checked the factory stickers for all the TTs and fivers. Roughly 1/3 did not specify ST or LT, 1/3 did specify ST and 1/3 specified LT. Most of the units that specified LT tires were the heavier brands like DRV.
So, if ST tires are so specially engineered for trailer use, how can rv manufacturers with expensive, heavy units "get by" without them? And if switching from ST to LT tires is such a risky thing, where are all the disaster stories from those owners on the forums?
larrytbm is offline   Reply With Quote
Old 02-28-2015, 08:53 PM   #28
North49's Avatar
I own a landscape company with 7 pickups, some new some older. Overtime I have standardized on the Firestone Transforce. Excellent LT tire for traction, durability, performance and reliability. The tire was also the tire that came on my last purchase a 2014 Ram 2500.
Brent/Barb -Zoe/Whizabeth wonder dogs
Palimino Columbus 320RS
2014 Dodge Ram 2500 6.7 Diesel
Calgary, Alberta The Stampede City
"The only things in life worth keeping are the things you give away"
North49 is offline   Reply With Quote
tire, tires
