Old 09-22-2016, 10:31 AM   #1
Lug Nuts
I have a stripped stud which needs replacing. While I am at it I want to replace those stock cheap covered lug nuts. Does anyone know what size or spec I need to order, or if you have replaced yours can you tell me which lug you used.
These are 8 bolt wheels, on a 6,000 lb axels. I have a 2013/14 Palamino Sabre 32 RCTS. I see these wheels a lot on other rigs. Mine are supplied by Lions Head.
Any help is appreciated.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-22-2016, 05:42 PM   #2
Jimsue's Avatar
I, too, would like to replace lug nuts on my 2013 Sabre that appear to be identical to yours. Two of them ( of the 32in all) appear to be stripped in that they spin when I attempt to tighten them. I am not quite sure how to remove them should the need arise.
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 09-22-2016, 05:48 PM   #3
Lug Covers
I think you need to find a way to rip off the spinning cover. Underneath the cover should be a nut you can grab. That is my understanding. Hopefully someone will respond with the info. If not I will eventually remove a lug and take it to a good auto shop to be sized.
Old 09-22-2016, 05:59 PM   #4
Ford Idaho's Avatar
In general terms.
Jack one wheel off the ground.
Remove that tire.
Remove center dust cap, hammer and a screw driver should work or a pair of channel locks.
Remove cotter pin and castle nut.
Pull the drum off.
Place the drum on a sturdy work station, place a old lug nut on a stud and then smack lug nut with a big hammer till stud drops free.
Or.
https://www.google.com/url?sa=t&rct=...4FuuzmGJHTHYww
Old 09-22-2016, 06:07 PM   #5
Iwannacamp's Avatar
Originally Posted by Ford Idaho View Post
In general terms.
Remove that tire.
Pull the drum off.
Or.
You can also a heavy drift pin along with the hammer. Makes the job easier.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 09-22-2016, 06:08 PM   #6
Bluepill's Avatar
Good method. Easier to use a hammer up/down than sideways.
Old 09-22-2016, 06:24 PM   #7
Ford Idaho's Avatar
I always seem to hurt myself holding one, locking it in a pair of vice grips has saved me much pain.
Old 09-22-2016, 06:51 PM   #8
Left Coast
Do as I say, not as I do......
