Old 12-29-2015, 07:10 AM   #1
Pirates55's Avatar
Main A/C
My camper is about 1 1/2 years old and my main A/C has stopped cooling. I had a mobile RV tech check it out here at the campground. The compressor is coming on but the amps are low. Was pulling 6 amps and should've been between 9 to 14 per the tech on a day like today. It was 76 degrees outside and about 78 degrees inside. Unit ran all day the day before and couldn't get the inside to 72 degrees when the outside temp was only 76 degrees. Most likely cause he says is a slow leak in freon. He says it's a sealed unit and not much can be done but replace the unit.
Guess I'll take it back to the dealer to have replaced. Thank goodness it's not real hot this week in myrtle beach and I've got a second unit in the bedroom.
Sent using Tapatalk
Pirates55 is offline   Reply With Quote
Old 12-29-2015, 08:02 AM   #2
I am sure Members in the (0-20 Deg.F) area's can Feel Your Pain! Youroo!!
Old 12-29-2015, 08:37 AM   #3
mud yapster's Avatar
It's only a sealed system because the factory didn't install taps on the system so refrigerant pressure readings can be taken. Last year after taking delivery of ours the bedroom A/C wasn't working properly. I could find a leak on the unit and had read the units were coming from the China plant under charged. I installed access valves and weighed in a factory charge of 18 oz. R410a. My bedroom Unit operating properly now and didn't have another issue all summer. Yes it was under warranty but didn't want to hassle with the dealer so I just fixed it myself.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 01-27-2016, 02:51 PM   #4
Pirates55's Avatar
Took the unit to my dealer and they tested the Main A/C and said it was bad. They changed it out with a new A/C under warranty. They mentioned that Dometic had a bad run and that they had seen quite a few go bad recently.
Old 01-27-2016, 03:01 PM   #5
TURBS's Avatar
Totally true, iirc it was mostly 15k units.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-27-2016, 03:16 PM   #6
Pirates55's Avatar
Mine was a 15K unit
Old 01-27-2016, 03:21 PM   #7
Mr. Dan's Avatar
Thanks for reporting back with your resolution.
We like it when a plan comes together!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
