Old 11-26-2014, 03:54 PM   #1
Manual Slide Operation
Any guesses out there if I use the below bit, a flexible drill extension and an 18V battery operated drill if I might be able to open and close my slides in an emergency? Maybe a power drill will do better? I have no access for a crank and prefer not to use a ratchet.
http://www.amazon.com/Electric-Quick...YG84BDE5P4458B
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 11-26-2014, 04:08 PM   #2
offroad's Avatar
I have one that looks just like that, but I have never tried to use it.
I'd be using it with the same 20V cordless drill I use on my stabilizers.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 11-26-2014, 04:13 PM   #3
I cannot get straight in with the drill hence the extension. I guess I will buy the bit, not too expensive and the extension I will by at Home Depot so I can return if it doesn't work. I will need the bit and a ratchet if the drill thing doesn't work.
manual, slide
