Old 01-30-2013, 08:28 PM   #1
Cyoul8r's Avatar
ManualOperation of Power Awning
I have a 2012 Palomino Sabre 32RCTS with a Dometic power awning (model 9100 I think). I don't have an instruction manual and am wondering what the knurled knobs on the rafters are for after the awning is extended. I think they are to pitch the awning if needed. Do these knobs need to be tightened (even if I don't pitch the awning) when extending or retracting it or are they to be loose? Also, what's the procedure to retract the awning in case of a power failure?
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 01-30-2013, 08:41 PM   #2
TURBS's Avatar
read this !
Forest River Forums - Downloads - Awning - Dometic Power
Old 01-31-2013, 08:09 AM   #3
Trailer Trash
Ahhh, were is the pull strap that is supposedly provided. The pull strap is what you hold onto to slowly let the awning roll back up. Is the strap stored/hidden in the inside leading edge of the awning? Never looked for it myself obviously.
joelek is offline   Reply With Quote
Old 01-31-2013, 08:14 AM   #4
Herk7769's Avatar
Mine was missing too.
Awning Pull Strap - Intersource Enterprises D10-207 - Awning Accessories & Hardware - Camping World
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-31-2013, 08:51 AM   #5
TURBS's Avatar
Mine was and still is missing.
Hope I don't need it ever!
Turbs
Old 01-31-2013, 08:58 AM   #6
Herk7769's Avatar
Turbs
There are many ways to cobble one up if you need to.
Obviously having one designed to do the job is preferred.
Awning tapes and a string, if nothing else.
Name:	Awning Tapes.jpg
Old 01-31-2013, 09:02 AM   #7
TURBS's Avatar
Yeah I suppose I should be more prepared on this deal .
I'll run over to the rv place today.....
Old 01-31-2013, 09:04 AM   #8
Herk7769's Avatar
Way better than taking it off and storing it inside.
Make sure you have the tools to do that...
Old 01-31-2013, 09:10 AM   #9
AKA: 'tiredTeacher
awellis3's Avatar
I read it and I'm wondering two things: 1) How often do these awnings fail? 2) Why does a "qualified service technician" need to be involved after the fact? If the awning had to be manually retracted because of a power loss (let's say I am boondocking and someone stole my battery), why does it now have to go in to be serviced?
Wright
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-31-2013, 09:31 AM   #10
Herk7769's Avatar
Wright
There is a humongous spring in there to unload the motor. If you remove the screws to change the motor and don't know what you are doing (or even that the spring is there) you can lose fingers.
I think there are a couple (not many) awning threads involving failures here.
Old 01-31-2013, 09:31 AM   #11
I have the strap that came with the awning, but I also carry a spare motor & torsion spring I bought off ebay.
Old 01-31-2013, 09:54 AM   #12
TURBS's Avatar
Wright
Think about your heavy garage door spring all wound up and tight!
Old 01-31-2013, 10:31 AM   #13
AquaMan's Avatar
Or as one member found out, not too long ago, it could break your thumb.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-31-2013, 10:37 AM   #14
Crusader's Avatar
I was reading my awning manual eight months ago. I read the part “ you will have to use the strap provided to manually roll up the awning”. Looking thru my bag of manuals and goods, I did not find a strap. I called Dometic, and they sent me one at no charge.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 01-31-2013, 01:05 PM   #15
AKA: 'tiredTeacher
awellis3's Avatar
There is a humongous spring in there to unload the motor. If you remove the screws to change the motor .....
But what if I had to roll it up 'cause I had no 12V power (damn battery thief!)?
Couldn't I remove the screw, deploy it using the strap, and reinstall the screw? If the awning didn't malfunction, why need a tech?
Wright
Wright and Penny
Richmond, Va.
Old 01-31-2013, 05:10 PM   #16
Cyoul8r's Avatar
Thanks for the links turbo and herk. Now I understand how to roll it up manually and I'll have to pick up a strap at CW. But can anyone explain how to use the knobs that are on each rafter? Are they supposed to be tightened after deploying the awning and then loosened to retract it or do I just tighten them and roll the awning up or down?
Old 01-31-2013, 05:47 PM   #17
TURBS's Avatar
Tightened after deployment.
Loosened before retracing.
Yes they are for dipping the awning for water run off.
They can remain tight at all times tho.
Turbs
Old 01-31-2013, 06:55 PM   #18
If you have poles to support the awning, (as a few of us do) I leave the knobs loose as they are not needed if the awning is tied down. The tie down straps and poles take all the load off the arms. As for someone stealing you battery(ies), all you have to do is plug in you tow vehicle to have power to the awning.
Old 01-31-2013, 07:12 PM   #19
TURBS's Avatar
Good catch on missing battery/ies tow vehicle plug in recommendation!
Old 01-31-2013, 07:24 PM   #20
Denver, CO
garbonz's Avatar
When I picked up my new vcross a couple of weeks ago, the walkthru guy nonchalantly handed me this rolled up strap and said " it goes with the camper". Now I know what it does.
Garbonz
2017 Fuse 23T
awning
