Old 07-21-2014, 05:15 PM   #1
Modification idea
I am in need of a jack knife sofa. I want to try to turn my slide out of my 25' puma 5er into a bunk area. My plan is to have a jack knife sofa on bottom with storage underneath and a twin fold up bed on top. Any ideas or suggestions. Has anyone done this before?
We bought a new rear living 25' 5er in 06 thinking we would have time to grow into it once we had kids. We'll we adopted 3 siblings at once so pretty much over night the camper was to small. We want to save up to buy another one in a year or two so I figured this would get us by for now
sbreen is offline   Reply With Quote
Old 07-22-2014, 11:49 AM   #2
My only concern is the walls. Not being designed for a bunk, will the wall hold the weight? Are the walls made any different in a regular bunk house? If they are not I guess it would work, but I don't build em, I just enjoy em! (and occasionally complain about what I believe are stupid engineering ideas, or just lack of critical thinking skills)
Good Luck!
David 01 is offline   Reply With Quote
Old 07-22-2014, 12:00 PM   #3
I think the walls in a regular bunk house slide model is the same as regular sides. If not I can make a frame to hold the bunk. I think I am leaning towards a futon for the bottom bunk now
Old 07-22-2014, 12:11 PM   #4
jevanb's Avatar
Our last tt got the master bed room stripped and 4 sleep in their . Me and the wife sleep on the living room floor on a blow up. That lasted 2 years untill our current
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-22-2014, 12:40 PM   #5
Plain Old Member
sbreen, I really admire you on this one. I'm an adopted child, so I think that is too cool. I honestly don't think the walls are any different in a bunk vs. non-bunk slide, at least from all the ones I've looked at and studied. Either way, I know you can make it work, and think you could do a LOT better than some OEM configuration. I like where you're going with this. Please post pictures.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-22-2014, 09:32 PM   #6
I picked up the futon today that I will use for the bottom bunk. I will remove legs and build a base with storage for it to sit onClick image for larger version
Name:	ImageUploadedByForest River Forums1406082566.669181.jpg
ID:	58746Click image for larger version
Name:	ImageUploadedByForest River Forums1406082741.780298.jpg
Old 07-22-2014, 09:40 PM   #7
Plain Old Member
Pretty nice set up. Now to get it in the RV.
Old 07-22-2014, 09:45 PM   #8
I have to pull out all the other things in that area first. This is what it looks like now. This is what I'm turning into a bunk areClick image for larger version
Name:	ImageUploadedByForest River Forums1406083474.560669.jpg
ID:	58750Click image for larger version
Name:	ImageUploadedByForest River Forums1406083492.705889.jpg
Old 07-22-2014, 09:58 PM   #9
asquared's Avatar
My question is, can the slide out handle the weight? I think with the window there I would go for making a bunk bed frame. I think it would probably be sturdier. What about putting the bunks and futon where the sofa is? Are you keeping the sofa or dinette? You could move the sofa to the slide if you are keeping it. And thank you for giving 3 children a loving home.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-22-2014, 10:06 PM   #10
I'm leaving the couch that is where the door to enter the camper. I will remove everything in the dinette area
cat, modifications
