Old 10-09-2016, 07:46 PM   #1
My latest simple mod
We like a window open in the bedroom but besides the emergency window the only ones we have are right next to our heads and we don't like to sleep with the air right next to us. I did the following mod that allows me to open the emergency window to a few different openings depending on how much air we want. I am sure there are other ways to implement this if one does not want to put the pin receptacle into the dresser, we didn't mind. I also like the idea that it does not really impede the use of the emergency part of the window. I thought about a pin on a piece of wire attached to the window but think this is a better implementation.
Just thought I would share.
ID:	122522   Click image for larger version
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 10-11-2016, 09:46 AM   #2
Thanks for the tidbit!
Thanks for the idea, David! I'm always looking for solutions too!
MissouriBob is offline   Reply With Quote
Old 10-12-2016, 09:46 AM   #3
Make sure
Make sure you place the pin out of the way of the shade so you can pull it all the way down.
Old 10-12-2016, 09:54 AM   #4
I had the same issue in both of my campers and ended with cutting a shim that would wedge in where the metal goes thru the frame. This makes it basically infinitely adjustable for how open you want the window to open.
Worked so well on the first camper, it came with me to the next one.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 10-12-2016, 10:04 AM   #5
Ree
Genius, idea. We will have to copy that one, Thanks!
2014 35 V-Lite 30WIKSS Platinum
Expedition 5.4, Hankook, Reese 1200 Round Bar, Trans-Go, Hadden, Curt Tri-Flex, 3.73 Posi-Traction
Ree is offline   Reply With Quote
