Old 11-14-2013, 06:21 AM   #11
Incheon, S. Korea
BigBaron's Avatar
That's what a 3/4 ton with a big fiver looks like-headlights skyward. Bags will fix that. Be safe and enjoy your awesome fiver!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 11-14-2013, 10:21 AM   #12
Originally Posted by LaydBack View Post
Congrats, and yes I too installed air bags on my dually. The link in my sig should have pics. I installed AirLift and their wireless onboard compressor. I like it and the on the fly control is great. I can change the ride without stopping.
I wish I was more of a do it yourself person, but I flat out don't have the time. I called one of our local air bag installers. They install Firestone Ride Rites. Almost all of their installations run the compressor tubing back to the license plate (one on each side). He basically tried to talk me out of using an onboard compressor. One reason was for the cost. Second, the compressor only comes with a 90 day warranty. Third, it has to be mounted in a dry location. They usually try to put it in the cab. There is no way it will fit in my cab, plus the noise would probably be unbearable. I am curious of where you mounted your compressor and any concern about premature failure. Adjusting it on the fly sounds really nice.
Thanks.
RadColt is offline   Reply With Quote
Old 11-17-2013, 10:02 PM   #13
LaydBack's Avatar
Thanks.
Compressor is weatherproof and water resistant. It's mounted under the bed. I have the manual fill valves at the license plate also.
WirelessAIR (Air Lift 72000, al-72000) On Board Air Compressor System | Air Lift Company
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 11-24-2013, 07:40 PM   #14
speedcat's Avatar
I added the Firestone air bags to my Silverado HD and it works perfectly. I use a portable air compressor prior to hitching. You will find the correct pressure to add after towing a few times. My optimum PSI is 52. It will also depend on your pin box. Did you get the trail air rotoflex rubberized pin box?
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 11-25-2013, 08:18 PM   #15
Thumbs down
Yes on the trail air rotoflex rubberized pin box. I think once I get it leveled out with the airbags, I should notice a smoother ride. Right now it is pretty bouncy and jerking. The Airlift Ultimate 5000 airbags are on sale with a $50 rebate. I am thinking about pulling the trigger on the Airlift 72000 wireless onboard compressor. It also has a $50 rebate. I've read that Airlift and Firestone make quality bags.
Old 11-25-2013, 08:35 PM   #16
Thanks.
My onboard air compressor has been riding under the drivers seat under the trucks (2) for 13 yrs and still works great.
Old 01-17-2014, 08:04 AM   #17
Pirates55's Avatar
I have the air lifter 5000lb air bags on my F-350. Mine are the manual fill, I installed them myself and ran the lines to the back bumper beside the tag. I level my truck at the house prior to leaving for a trip with my air compressor in the garage and its always been fine. When I get home I let the pressure back out to about 10lbs when not towing anything. They work great. Just be sure when you call to order a kit you specify the type of hitch you have. They have special applications for several of the 5th wheel hitches.
I had to send my first kit back because it would not work with the B&W turnover ball so learn from my mistake.
Pirates55 is offline   Reply With Quote
Old 01-17-2014, 10:26 PM   #18
CBergstrom's Avatar
I have this compressor too. I mounted mine in the truck box under my roll'n lock can. I wanted to mount it in the engine bay but no room for it in the Dodge. Works great and it doesn't run that often when pressured up but I still wouldn't mount it in the cab.
CBergstrom is offline   Reply With Quote
Old 01-17-2014, 11:00 PM   #19
Mine is mounted under the truck right below the drivers seat. Been hanging there for 13 yrs on 2 different trucks. Still works great. Only time it comes on is when I press the button or let it down to minimum pressure and hit a swale in the road and the truck frame unloads the airbags and triggers the compressor. The compressor automatically maintains 5# IIRC.
sabre
