Old 05-25-2013, 04:00 PM   #1
Don and Elaine's Avatar
New Columbus 320rs tires
We just purchased a new 2013 Columbus 320rs but noticed that the tires on it were an unknown brand to me. I was wondering what tires came with other Columbus 5th wheels and what the track record is on these brands. We had problems with Carlisles a few years ago on another TT so of course an unfamilliar brand is of some concern to me. Looking forward to our first trip out with it but we will have to wait 10 days to pick it up!
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 92 days in 2017, 94 days in 2018, 108 days in 2019 and 112 days in 2020.
Don and Elaine is offline   Reply With Quote
Old 05-25-2013, 04:52 PM   #2
fonzie's Avatar
What brand do you have on your trailer?
Fonzie
Old 05-25-2013, 05:08 PM   #3
BigTJohn's Avatar
Probably Akurat tires. They are not a super, well known brand but they are good for the job. Just keep an eye on pressure and look at the tread (like you should do on ANY tire) after each pull or when stopping for fuel. Feel the tire(s) surface with the back of your hand and you will note there is a major difference in operating temp. Just try to recall if you had rough roads just before stopping or a short fast curve you just negociated that may have heated up the tires on one side. A tire minder type of electronic (I know, something more to buy) monitor will really save your bacon not to mention greatly reduce any damage to your 5th wheel if there is a tire problem, by alerting you to impending failure. Most, if not all tires coming with a new trailer are within specs as far as the DOT is concerned but ENSURE they are rated for YOUR trailer. Just look at the sidewalls and if they are the tire spec'd for your trailer weight, etc. then you should be OK. When their time is up, and I mean time, not necessarily miles, buy the best tire you can afford. At least you then have piece of mind from that expense, for a while, of course something else will come up and...
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 05-25-2013, 05:58 PM   #4
In my opinion and if you can afford it, I would pull the trailer from the dealer directly to a tire shop and put the next size larger, up the load range one notch and balance new tires from either GY Marathons, Maxxis or a major brand tire with a mfg date of not older than 2612. My experience with all OEM tires is it is not a matter of will I have tire trouble, but when.
Old 05-25-2013, 07:05 PM   #5
Great advice from Big John. Run the tires you have, but keep an eye on them as far as pressure goes. They are probably the same tires I have on my 320RS. If you want to change them out after a few years, then do so.
Just don't waste money when you don't need to.
SargeW is offline   Reply With Quote
Old 05-25-2013, 07:38 PM   #6
semi-senior member
denandra2's Avatar
Weatlake brand tires on my 2014 320RS I took delivery on 5-7-13. They have a good looking tread pattern on them! I plan on running them two years max and then change out. Congrats on your 320, hope you like yours as much as we like ours!!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-25-2013, 07:50 PM   #7
amxpress's Avatar
I also have Akuret tires and so far, knock on wood, they're doing well.
National tires results
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-26-2013, 07:13 AM   #8
Thanks for the info...I believe my FW has weatlake tires. I have always taken care of my TT tire, proper inflation, covering etc. When the time comes, around 4 years from now, I will probably replace them with Maxxon tires as they seem to have an excellent reputation. Now I need to unload my current TT and store everything acumulated from 2009 when we purchased our Flagstaff. I am trying to remember if the slides on the 320rs are electric or hydralic along with a host of other things, as well as print out a PDI sheet for our walk thru on 6/8 when we take delivery. I have seen many post about mods on this unit so I will also have to back and see which ones might work for us!
Old 05-26-2013, 07:20 AM   #9
Originally Posted by Don and Elaine View Post
Thanks for the info...I believe my FW has weatlake tires. I have always taken care of my TT tire, proper inflation, covering etc. When the time comes, around 4 years from now...
If you take many long trips, I would wager you will not make 4 yrs before having to replace them even if you keep them properly inflated, etc. I sure haven't experienced any luck with oem tires on rv trailers.
