Old 07-16-2019, 08:52 AM   #1
New owner with another problem
Yesterday while exploring my new 2019 Palomino Solaire 258 RBSS I opened up the storage area underneath the bed. I wanted to take out and assemble the out door gas grill. And now I cannot figure out how to unlock the two extension arm supports that hold the lid open. I did not think to photograph these parts, but if anyone has a suggestion, I would appreciate your help. Thanks much.
flyboy43 is offline   Reply With Quote
Old 07-16-2019, 09:08 AM   #2
They should be hydraulic struts and should just close. On our 2013 my wife has a hard time closing ours
captrcurtis is offline   Reply With Quote
Old 07-16-2019, 09:18 AM   #3
If your extension arm supports look like this they are pneumatic (gas) struts/shocks.
There is no locking mechanism and force is all that is required to close.
Depending on shock pressure (available in different ratings) it may take a strong push to overcome the strut/shock.
Be aware once you get past the initial effort needed to close the bed, it may slam shut as the strut/shock doesn't let the bed close slowly, it only holds it open. They have no liquid in them and are not hydraulic.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 07-16-2019, 10:08 AM   #4
Thumbs up Thanks for the help with the bed storage lid supports
To all who so promptly replied to my question - THANK YOU! This forum has been the best help to me as a new travel trailer owner. BETTER than my dealer.
Old 07-16-2019, 09:06 PM   #5
Thumbs down Update on the under the bed storage area on my 258 RBSS
FYI, I tried pushing evenly on the lid, expecting to overcome the resistance as described by others. All that happened is the right hand bracket screws, (which look too short to me), broke free of the wood. So rather than mess with this issue any more, I removed both the brackets attached to the lid. So now I can close the lid. Not what I expected with a brand new RV.
Old 07-16-2019, 09:09 PM   #6
Post a photo of the supports.
Old 07-16-2019, 09:39 PM   #7
Thumbs up Photos of the problem brackets
I will take some tomorrow and post them.
I have my RV in a secure storage facility, and will head over there Wednesday am.
Cheers, from the new guy.
Old 07-17-2019, 01:47 PM   #8
258RBSS Solaire hardware
Here are two photos I took this am of the "does not close" hardware that was installed in my new travel trailer.
ID:	210133   Click image for larger version
Old 07-17-2019, 02:45 PM   #9
Those are pneumatic (gas) struts/shocks and have no locking mechanism.
Once removed, unless something came apart internally you should be able to hold the larger barrel end in your hands and using your weight, push the rod end against the floor and collapse. Once released the rod end will extend again as it is always under pressure.
Looks like they are 60# shocks so somewhat stout.
It is possible they were installed incorrectly (incorrect angle) or as you mentioned, maybe the screws were too short to hold.
Old 07-17-2019, 03:07 PM   #10
Bought the heavy duty shocks for mine. Factory used the wrong shocks.
When installing the bracket on the plywood there are two screws to sort of hold it in place, then you are supposed to drill the third or more hole for a nut and bolt.
Kind of appears they forgot that step?
tomkatb is offline   Reply With Quote
