Old 07-09-2012, 10:37 PM   #1
Great Horned Owl's Avatar
New Puma
This afternoon, I picked up my new Puma 253-FBS I only towed it about 20 miles back home from the dealer so I don't have a real feel for it yet. Backing it down my 220' narrow, curving, driveway wasn't fun. I've never driven a trailer before.
So far, we've found a few small issues.
I lifted up the bed and the struts locked. I absolutely can not find any way to release them. I had to unscrew them in order to let the bed down.
The manual talks about a manual crank in case the slide won't move. It has a drawing of the crank, but where is it? Speaking of where, is there a gauge for propane level? If so, where is it?
The dead bolt on the door works from inside, but will not work with the key. I am hoping that it might be easier to fix myself than to go back to the dealer. Unless somebody knows the solution, I'll investigate tomorrow.
We got the rear stabilizer jacks, but have not seen a need to put them down. Even without them and with only basic wheel chocks, we don't notice any movement as we walk around.
I'v got it parked in the driveway and we plan to move in for a few days to do a thorough check. At this point, we are pretty happy with it.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 07-10-2012, 07:08 AM   #2
LGreeves's Avatar
You will absolutely like how the rear stabilizer jacks work when used.
2013 Palomino Sabre 34TBOK
Pulled with '99 2500 Silverado Ext-Cab
LGreeves is offline   Reply With Quote
Old 07-26-2012, 08:37 AM   #3
rce
Joel
Did you find a solution to your struts locking?
I had the same problem last night. Can't seem to unlock them. Did you have to buy & install new ones?
rce is offline   Reply With Quote
Old 07-26-2012, 09:04 AM   #4
No. I just unscrewed one end.
Joel
