Old 01-01-2013, 03:31 PM   #1
New Year Med Cabinet MOD
I decided that New Years Day woud be a good time to start a medicine cabinet modification in our 32 RCTS Sabre. The plan was to remove the cabinet and add a few extra shelves and dividers.
To get started , I removed to door to make it lighter. Then I removed the 10 coarse thread screws holding the cabinet to the wall. To my surprise, the cabinet was still attached. Upon further investigation, I found that the cabinet was also nailed to the wall in several places. I'm not sure if I want to remove the nails at the risk of causing damage.
I'm now curious what's going on Why both nails and screws. If I decide to remove the nails, do they need to be repaced. Seems like overkill or am i missing something else? Any ideas.
btw..Happy new year fellow campers!
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 01-01-2013, 05:22 PM   #2
mike54's Avatar
it might also be nailed and screwed from the back side too
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 01-01-2013, 06:20 PM   #3
2012 Solera
Don't know anything about the med cabinet attachment - in similar situations (not wanting to do damage) I have center punched and drilled the heads off nails, then drove them in rather than pulling them out.
JLeising is online now   Reply With Quote
Old 01-01-2013, 08:19 PM   #4
VinceU's Avatar
Wondering if a power nailer is used to position cab first followed by someone with coarse wood screws for permenant attachment. Wouldn't require extra labor to hold it while screwing.
VinceU is online now   Reply With Quote
Old 01-02-2013, 05:37 PM   #5
I took another look at the Med Cab today and I'm pretty sure VinceU hit the nail on the head. (No pun intended) I can see the small nail heads around the edges and It looks like they were just used to set the placement.
I'm still goining to leave it in place whil;e doing the mod however, because we also found that the cabinet sides are actually semi-stuck to the wall board covering, probably due to being installed before the stain/varnish was fully cured.
Cathy & Jeff
Midland, Michigan
