Old 05-18-2012, 08:00 PM   #11
Unruly's Avatar
I have the same Fiver as you and we hardly hear the fan. Even with the door open it's very quiet. I would contact your dealership and see what they say. What you are describing is not right.......
Bill and Sarah
Edinboro Pa
2008 F350 Lariat Crew Cab Diesel DRW 4X4
2012 Sabre 34REQS
Unruly is offline   Reply With Quote
Old 05-19-2012, 05:03 AM   #12
Your correct,the ref.was not in the tip out. Iam going to put dealer on notice about moisture and keep close eye on it myself.delamanation is not good.
Duchie
duchie is offline   Reply With Quote
Old 05-19-2012, 06:25 AM   #13
The fan is mostly annoying during the night when you sleep because of the constant cycling on and off. To help this situation i installed a fan from a refrigerator ( the one that you have in the freezer compartment ) and now the built in fan does not start all the time and you can sleep at night. Have a look at my picture.
ID:	14081   Click image for larger version
capucine is offline   Reply With Quote
Old 05-19-2012, 06:51 AM   #14
Looks like you do very good work. however your missing my point,why should someone who doesnt have your ability have to put up with this problem,when a company that makes tons of money stands by a chooses to ignore it because it might cost a few dollars to make a wrong a right.
And still you have the moisture problem---which be a bigger problem then the noise.
DELAMANATION
Old 05-19-2012, 09:10 AM   #15
bob213's Avatar
Where is the moisture coming from? Where is your drain hose? Does it drain to the outside? Does it have the cap on the end with holes in it? I hope you get this fixed. You are right, we shouldn't have to do all these add ons to make it work correctly, but yours seems abnormally bad. Good luck with this situation. Let us know how it turns out.
bob213 is offline   Reply With Quote
Old 05-19-2012, 09:17 AM   #16
J_KHawthorne's Avatar
Originally Posted by duchie View Post
I have a new 34reqs and the refrigerator is the worse I have ever seen. I have owned 2 jaycos and 1 forest river and I have never had one that the refrigerator runs almost constantly. The 12 volt fan they put in it sounds like a electric drill running. You can hear it in the bedroom with the door shut. I also took the cover off at the top where the ref. vent is, I guess for the fan and I noticed quite abite of moisture. Is this going to cause delamination??????
Duchie
This was my solution...
Crusader 290RLT fridge fan noise
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 05-19-2012, 10:07 AM   #17
Bob 213
Take the top vent off and there is a flimsy pc. of plywood across the opening. Behind that is the top of the refrig. and a silver pc. of foil and that foil and in that area is wet.
As for the drain hose for condensation it is there but I have never seen any water drip out of it yet ??????
Duchie
Old 06-08-2012, 07:14 PM   #18
Oddjobs
Just got a new Sabre 31CKTS yesterday and today the refrigerator strated making a load whining sound. Is that normal? Never heard a peep ot of my previous refer. in my motorhome. Any thoughts?
Oddjobs is offline   Reply With Quote
Old 06-08-2012, 07:43 PM   #19
Regarding the moisture, is the fridge drain hose sticking out through the vent cover? I am amazed how many are not.
Funny about the fan thing, as ours doesn't have one either, thankfully.
DonG is offline   Reply With Quote
Old 06-09-2012, 07:57 AM   #20
lindy's Avatar
My solution to the noisy fan was to take a $2 yard sale 12" box fan and set it on the shelf for the grill on the side of the trl. My shelf could set right below the frige vent on the side of the trl. I'd point the fan into the vent and set it on low. Once the box fan was on the fridge fan didn't come on again.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
