01-20-2013, 11:32 AM
#121
Trailer Trash
Regarding the 6 way leveler and rear sensor issue.......instead of forcing or cutting, ask LCI or whoever makes this unit how to bypass the sensor or sensor fault. This would be done on the logic board I would guess and may be as simple as unplugging, resetting, or jumper wire to clear the fault.
01-20-2013, 11:45 AM
#122
Trailer Trash
I would also ask owner of lala land for an extra week or two till weather warms up to move rv. Apologies forgiveness etc is in orderof course. I realize the pissed off level falling out situation and say f it cut losses. However, moving during -30 temp is crazy.
Im also convinced the older RV units are waaay less controlled by microelectronics. Not as nice or as fancy, but more reliable sometimes. Sales lady I had at Appliance Mart has sold home appliances for 30+ years. Display and logic boards in home apliances fail all the time nowadays. Not really an issue 10 years ago she said and I agreed with her.
01-20-2013, 04:42 PM
#123
Originally Posted by ranchand
You exemplify "when the going gets tough, the tough get going" Hang in there. Glad to learn about the screen door. I saw a new model on a lot and noticed that the factory started putting on screen doors and I want one. Looked into it and the entire factory installed door has to be replaced with a new door/screen door and frame. Over $800. Too much for me! I agree with you--fit and finish could be a little better. The factory assembles these units in three days. And, I have spent a couple 100 degree days and the air conditioners run a lot! I installed a 12' awning over the dining room/living room slide windows. Looks like that will help knock off the sun and help with the cooling. Won't do much for -15 degrees! Big windows????
We use that aluminum bubble wrap cut to fit to cover windows under the blinds. It keeps the light out and really keeps our RV cool and does not look bad behind the blinds.
01-20-2013, 04:58 PM
#124
Originally Posted by GypsyFamily
So we have a major problem here. Our lala land existence in the world of free electricity is now over after a falling out with the property owner of this rv park. We must move the rig by Monday 21 January, we have a place to go and all but we cannot move. Literally we cannot move.
We elected to have the 6pt leveling system and that system has, according to LCI, a failed "rear sensor". That sensor is creating a persistent error code to appear on the control panel that makes it impossible to use the control panel. So the next course of action would be to manually retract the landing gear right? WRONG. To all 385bh owners / prospective owners, I challenge you to go manually retract your middle two jacks. There is actually NO way to reach those jacks with the tool provided. You literally cannot retract the middle jacks manually. So I spoke with LCI about this, and apart from agreeing that the design was lacking common sense, I have to connect a battery to each motor and retract each jack via that battery, OR just cut the things off with a cutting torch.
SO, lets recap, the roof leaks in half a dozen places, the microwave no longer works, the aft TV no longer works (wont connect/stay connected to our network), the fridge no longer works, AND it cannot be moved. The roadside assistance people came out, and tried to lift it high enough for me to get my truck under, but that failed and they left suggesting we hire a CRANE to lift it onto a flat bed.
At this point we're absolutely sure we've made the worst decision of our lives buying this thing. The only thing that could possible save this situation is the folks at Forest River doing something about this. If they do not, and I'll let you know if / what they do, my suggestion would be to STAY AWAY from these products, and consider highly suspect any product made by Forest River.
If ANYONE has any idea of how I can get this thing underway, PLEASE let me know. If I'm wrong about the middle jacks, PLEASE prove me wrong, I'd be the happiest man on earth. At the same time, if anyone know's where this "rear sensor" is for the LCI 6 way levelers let me know. It's -30 here, we're in a hotel not our home, and this is getting extremely tiresome.
We all desperately miss our Itasca Sunova 35J at this point. We never had a problem with our bus, but this thing?
A lot of time disconnecting the battery for a period of time will reset the electronics. It may be due to extreme cold but unbolting jack could also be an option. Electric jacks can be disengaged by removing motor and hydraulic jacks can be released by bleeding the fluid in a worse case senerio. I hope everything works out for you.
01-20-2013, 05:02 PM
#125
We only run the furnace for about 1hr in the morning just to boost the temps until the sun comes out around 8-9am. When it's going to be below zero all day we leave the furnace set to 58degrees and it usually runs all day (with the fireplace, two 1500w electric/oil radiators, and one 900W ceramic heater). But it's been a couple of months since we've used one of the 20# tanks. At the rate we use propane we'll only have to fill the 250# once a year or so. NOW, if we had to pay for our electricity, we'd use the propane MUCH MUCH more, and when we bring the rig to Eelpout we'll have a bigger test.
Here's a question: how long does the battery last and does it run the furnace? If not what kind of generators do all you use, and how much does your genne run, and how much fuel do you go through? We, foolishly in my opinon, did not get the gennie installed as we bought off the dealer floor.
I have the Honda 6500ic it runs everything in my camper and runs 11 hrs on a tank of fuel. If only running 1 AC it will run about 15 hrs.
01-23-2013, 11:16 PM
#126
Well so that's annoying, I just wrote this whole long post and my browser froze up...sigh.
Ok so Bottom Line Up Front, we got the rig out, and without cutting anything.
We had to leave the campground, I'm not going to get into why in this forum, but just to say, we had to leave immediately. We were not kicked out, quite the opposite, we just learned things that forced us to leave ASAP.
Ok so, today one of the tech's from LCI called and explained a simple way to retract the jacks to us non-electric types:
- Disconnect the two wires leading from each electric motor at each jack.
- Pull your vehicle around with jumper cables attached to your battery.
- Strip the wires back on the motors about 1" and attach the jumper cables to the stripped cables
- the motor should go either up or down, if you want to reverse the direction of the motor, reverse the jumper cables on the motor cables.
Easy? YES, but too late. We didn't do it this way.
We managed to heat the front landing gear enough so it would move, then spent about 2hrs jacking the landing gear up 2" so my F350 would fit under the front and dock. Which it did, and I litterally jumped for joy. Then we cranked it back down and lifted the feet into the jacks. As there is no descernable way to jack up the middle two feet, we took the tire jack out fo the F350 and jacked against the frame at each of the remaing electric jacks. This allowed us to relieve enough tension on the foot to pull the pin and push the foot back up into the jack. Middle and back doing this took about 2hrs. It would have been quicker but it was -55 with wind chill and I move slower in the cold.
At this moment the F350 blew a cooling line and I lost an injector (yep same time) now with coolant all over the ground the truck spuddered to a halt. I fired it back up, and now am the proud owner of a 2004 Ford F350 air cooled 6.0l V7 Powerstroke Even with only 7 cylanders firing it still managed to drag the 385 to Duluth.
To their credit both LCI and Forest River called all day Saturday and Sunday. Monday we got the rig to Bullyan's RV in Duluth, and, because they are awesome, it's in the shop now for a "few weeks" dealing with the jacks, leaking roof, fridge, etc.
What a drama.
The only horrible terrible thing to come from all this is that this little tiny hotel room is getting smaller by the minute we're probably going to have to, I can't even say it...move into a house.
Shame.
A house. With a foundation, and a roof, and it doesn't go anywhere. Ugh. Just sits there dumbly and can't move.
So I wanted to thank all of you for your words of support, for the tips, ideas, tricks. For all your PMs, Calls, emails. For those of you who challenged us, and supported us. Our journey is NOT over, even with this house thing. Though it looks like our winter is over in the rig, we'll be back in it in no time. And mabye now we can pull the ice castle out to where it belongs (on the ice!) and catch a 'pout or two!
Thanks again, and we'll continue this post as we learn more about what all went wrong with the camper, and what was done to fix the issues so we can all continue to learn something.
Thanks again,
Sam.
01-24-2013, 01:32 AM
#127
There is no way you just said that!
I read your post and sorry things did not work out the way you wanted, but your coach is in for repairs and Forest River is backing you up. Good news for the most part.
Man, your browser froze up. Really I could not resist.
01-24-2013, 02:32 AM
#128
Right?
01-24-2013, 01:25 PM
#129
Phat Phrog Phlunky
Sorry to hear.you couldnt make it work. But it certainly wasnt for a lack of effort.
Best of luck Gypsy.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
01-24-2013, 02:45 PM
#130
Good try anyway, just that mother nature hit a little harder this year.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
01-24-2013, 03:10 PM
#131
What a drama.
Shame.
Thanks again,
Sam.
Glad you got in and taken care of Columbus will help you out. Hang in there!
01-24-2013, 06:11 PM
#132
Good luck to your folks. For those of us that lead a rather cushy life compared to yours, I have a lot of respect for your ability to deal with the elements. I hope things work out for the best. Cheers!
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
01-24-2013, 06:21 PM
#133
Sam & Family... you all have been in my thoughts with the cold (and mind you I am in Missouri) PROPS to all of you for the attempt!!! I have to say .... while sitting in my house -- it does just sit here dumbly.... the Earth Station calls me daily..... almost like Calgon.... Take me away!!!!
Thanks again Gypsy Family!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
01-24-2013, 11:42 PM
#134
Learned something today, granted this is from the dealer NOT the manufacturer, but we were told that the fridge is "not designed" to work in temps below 15deg F. Uh, that's a bit of a problem. Granted most of the camping community doesn't camp in below 15 degrees, but come on. I could maybe understand -15deg F, but 15 above zero? I have a chest freezer that sits in my unheated cargo trailer that doesn't have an issue, NOT to mention the fridge in the outside kitchen that was chugging away for a month in the MUCH colder than 15deg weather. So any of you that live north of Florida, you can forget about winter camping? I don't think so. Sounds like Dometic makes a crap product.
I think it's also worth mentioning that for years we had NO issues with our Norcold fridge in the Itasca for winter after winter in temps 15 degrees and colder. So, yeah. We'll be replacing that Dometic POS as soon as possible, just as soon as I can justify $5,000 on a fridge for the RV...Norcold Ultraline 1210MSSD. And just so you all know where my priorities are, I'd never even think about spending that much on a fridge for a building, but an RV? Yep, just need to save a little.
01-25-2013, 06:56 AM
#135
Commercial Member
I think I would verify that with the manufacturers of the refer rather than believe the dealer.
An RV refer is a completely different animal from a home type refer or freezer. They use compressors and freon, and your RV refer uses ammonia liquid that needs to vaporize to make cold. That is why they use an electric element or flame to make heat, vaporize the ammonia, and circulate through the coils to make cold.
Dometic, and Norcold both work the same way. Atwood has new technology out, that replaces the ammonia with helium.
Again, verify with Dometic and Norcold, both they both work the same way....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
01-25-2013, 09:09 AM
#136
phat phrog stunt crew
maybe you could look at it as a blessing rather than a curse. winter isnt over, and this just might work out for the best as far as the rest of this winter season is concerned.
01-31-2013, 05:17 PM
#137
So some updates,
The problem with the jacks on the rig was, as stated, a malfunctioning remote sensor. This malfunction was generated (according to LCI) by the "massive" amount of water in the underbelly. This water was noticed by the dealer's tech when he removed the underbody panels, apparently the insulation was saturated. This surprised me, the amounts of water the dealer was talking about, I would have thought would be dripping through the bottom of the rig and forming ice. We were able to keep the underbelly heated, but not above freezing. Usually around 20-28deg F, which was always enough to keep pipes from freezing (plus leaving the water dripping in the kitchen). The biggest reason for the underbelly heater was to keep direct heat on the low point drains which will freeze in a heartbeat if exposed to outside air. (Speaking of the low point drains, given the heater, and the insulation pictured in a previous post, when I went to open them to drain the water out of the unit they opened right up and drained, so insulating them was definitely a good call).
So the upshot was LCI said this water caused the short in the system, and said that the whole deal was Forest River's problem. Which thankfully Bullyan's told me, as apparently I, the lowly owner, am not privy to this info. I was thinking the RV was being repaired, but infact all parts were cancelled for the repair by LCI pending Forest River taking the unit back to the factory. I had discussed with Forest River the idea of coming down to the factory, but hadn't agreed on a time, day, month, or even if it would be possible given my work schedule. Apparently that decision was made for me.
A couple of days ago we get a call from Forest River asking when we're getting the unit to them, my wife told them we can't anytime soon, and asked if they could pick it up, which they agreed to. So we've emptied the rig out of all our stuff, and she's sitting on the lot, waiting to return to the motherland.
So much has happened, and there are still a lot of questions we have about what all is happening, but oddly we're not upset. I never imagined this would happen, we knew we'd experience difficulties, and test the systems, but we never deemed the unit would be going back to the factory. That being said, we still love our rig. It is still our home. That rig may have some issues that seem pretty big, but to be honest when it was -30 outside we were warm, dry, and VERY comfortable. The fridge broke, and Dometic still hasn't answered me as to why they put a fridge in an RV that can't handle the cold. Perhaps they should stick to boats. The microwave was replaced, and honestly rarely used. Bullyan's didn't get into the roof leak, as it's going back down south anyway, so better Forest River look into that vice the dealer. Even given all this, and the annoying things we've repaired, we still love the 385BH. I love the way it looks, I love the floor plan, the bathroom, washer/dryer (when we get one), the bunkroom...there are still 1000 reasons to buy one of these. My only caution would be that you must be patient. Forest River has been great to work with, which reminds me of one thing, then I'll sign off.
In 2008 I bought a mountaineering tent from LL Bean. Now, NOBODY buys mountaineering tents from LL Bean, Big Agnes, North Face, sure, but LL Bean...no. Sure enough we're way out in the boonies and we see about 8" of wet snow, and the tent collapses bending a pole beyond use. We made due for the rest of the trip and call Beans on the way out. By the time I got back home there was a brand new set of poles waiting for me. No questions, no issues, just instant resolution. THAT is what we as the consumer want, at least that's what I want. I don't need a perfect product, in fact I don't want a perfect product, I like to tinker. What I want is manufacturers who take ownership of their products and stand behind them when they fail. It seems that so far Forest River is one of those companies that stands behind their product. If they continue to do so, these rigs are worth their weight in gold because if they fail, you can rest assured that Forest River will pull you through.
We'll see, I have high hopes for Forest River, they've been great so far. I personally think before you know it we'll be back in our rig, happy. Getting her ready to be towed out to Colorado for our bi-yearly sanity break to the Western Slope. And if someone at the factory should slip and fall and throw a generator in that there rig, I wont tell .
As always, thanks for reading.
- Sam
01-31-2013, 05:19 PM
#138
Oh and we sold the fish house, so someone who actually goes ice fishing...
01-31-2013, 07:16 PM
#139
One last thing (for now), I just got off the phone with my wife who told me about a phone conversation she had with our dealer today. They obviously konw that Forest River is coming to pick up the rig, and gave it a quick walk through. In doing so they noticed that we'd left some things behind, that we felt were honestly of little concern to us. So they boxed up all the stuff we left behind and have it safe and sound at their shop. They clearly didn't have to do this, nor did they have to hook it up to a battery charger to make sure we had enough juce to put the slides out to empty the rig, or pull it around so it was easy for us to unload.
I've been to RV dealers all over the country, and read on this forum and others about all the great and terrible dealers out there. So far in all my years of RVing this dealer is the best. They bent over backward to help us get out of our Class A and into the rig (even to the point of our salesman (Andy) and the owner driving from Duluth to Hibbing to look at our Class A because we couldn't realistically drive it down for an assesment), the bent over backwards when the rig broke, and they're still bending over backwards to lookout for us (and our crap) while our backs are turned.
Good on you Bullyan's! Andy you and your sales team were and are great. George you and your servivce team are beyond reproach. Keep it up, and thanks for looking out for us!
- Sam
RV Dealer in Minnesota | The Best RV Sales in Duluth Minnesota
Look them up, at this point I'd drive here from Colorado to buy and RV in the future.
01-31-2013, 09:22 PM
#140
Denver, CO
Wow
I' m exhausted and am going to bed after reading this from the beginning. This is the first time I've read this post and I think it should be published.
Kinda like northern exposure.
What about a reality TV series called. Da frozen camper adventure, staring Sam and his frozen family. Really, it would be great.
Garbonz
2017 Fuse 23T
