Old 10-19-2012, 01:37 AM   #1
GypsyFamily's Avatar
Cool Northern MN in 385BH Full Time!
Hi everyone!
Ok, so I thought I'd open this up for some input. We are NOT novice fulltimers, in fact, I wouldn't own/rent/set foot in a house if you gave me one. I don't even like looking at them. We've lived in our RV (Class A MH) for a long while now, and have just slammed down $8500 on a brand new 2013 385BH, and will pick it up on Tuesday 10/23 along with our new to us 2004 F350 (I know 6.0 PS, worst engine ever, blah, blah). We've done this because the kids are no longer babies, and we needed more than 35 feet with the illusion of privacy, and some sort of "insulation" against the cold, and apparently I'm a masochist.
I've read all the threads on the first model year problems, and am scared sh--less that I just made the mistake of a lifetime giving up "Bussy", but that's not what I'm on about here. So yep, we currently live in Northern Minnesota on the Iron Range as I work at an iron mine. We will be here for 44 months, then BACK to Colorado . We will winter over 4 times with temps reaching negative 35degF with 4 feet of ground freeze and who knows how much snow. We will attempt to keep the water on, as we work camp at a defunct RV park and get free everything. We've stayed in our Class A through hurricanes, 3 feet of snow, earth quakes, angry red necks, and more, but never a Northern MN winter.
So we have a very comprehensive plan. If anyone is interested I will continue this post with our plan and our progress (and yes pictures). We are open to all forms of advice, help, insight, and corn whiskey. If there is no interest I will bugger off. If anyone is in MN and would like to stop by, PM me, you missed the pig roast (honestly so did I...too much firewater) but we can still tell old war stories and bitch about our rigs! Maybe go ice fishing/ice drinking?
Let me know folks.
Thanks for your time, Oh, and Christopher Columbus, if you're still around this site, please PM me preferably with a phone number where I can talk with a factory rep/tech.
Thanks!
GypsyFamily is offline   Reply With Quote
Old 10-19-2012, 06:16 AM   #2
TURBS's Avatar
Originally Posted by GypsyFamily
Hi everyone!
Let me know folks.
Thanks!
$ 8500.00. 2013 385bh? ?????
Old 10-19-2012, 06:26 AM   #3
Triguy's Avatar
I'd imagine that's a downpayment, Turbo.
Welome to the forums, Gypsyfamily!
We're a friendly bunch here and I look forward to hearing abut how this works for you.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-19-2012, 06:37 AM   #4
TURBS's Avatar
Whew I was goin to get me one of those lol!
To the op congrats and welcome to the forum!
Old 10-19-2012, 06:59 AM   #5
Campin' in Canada
ParkManCan's Avatar
Welcome! We're in Northern Ontario, pretty much due east of you so we know what you're getting into, much braver than us though, we've left the trailer for the warmth of our house. The DW is from Roseau, MN so she REALLY knows what's headed your way. Good luck!
2011 Wildwood 37bhss2q
Permanently Parked
Just me & the DW
ParkManCan is offline   Reply With Quote
Old 10-20-2012, 02:33 AM   #6
I feel better
Turbo, yes $8500 down. $8500 and our beloved bus. Sigh, all things must end.
Triguy, thank you, and I'll attempt to follow most of the rules.
So, honestly I feel better about these Columbus things after just spending 6hrs fixing my "rock solid" class A...3 Days before we get this 5th Wheel. So these things dont come with Generators and Sat dishes? Honestly I had no idea, I just assumed they did. I guess I get the generator, but $75k and no sat dish from the factory? Is this typical of 5th Wheels? Oh well, TV rots the brain anyway.
OK, so I've included couple of pictures of our set up. The 385 will go where the class A is now, hopefully it's level enough for the apparently kinda lacking leveling system. The Ice House is for the kids as a play room/bed room for me when I'm on nights so I can get some sleep. The cargo trailer is for all of our sh_t. We'll be selling that now that we're lacking a way to tow it (any takers?). Our plan may have to change a bit, but for the most part we're sticking with it. We intend on preventing/delaying ground freeze (which we see as our primary concern), by packing under the 385 with 4,000lbs of hay. We were going to use square bales in the class A as we needed to leave the mechanics exposed to run if needed, but I believe the entire underbelly of the 385 is sealed, and I can just pack hay in/around the unit until my little heart explodes. The water line will run on top of the ground, under the hay, wrapped in heat tape and insulated. If we can prevent ground freeze to the tap, we should be good to go. We'll probably end up heating the underside with a string of contractor lights inboard of the hay, but I'm slightly concerned with a fire hazard. I've never seen a 60w bulb light grass on fire, but i'm sure it can.
We'll not keep grey cracked as usual to prevent an ice dam from forming, so we'll just leave the connection, but have to dump/drain on tank fill. Do both grey/black tanks drain from a single point or do they each have their own drain/valve set up? We had a recommendation to wrap the sewer line with heat tape, I don't see this as being possible. I'm not inclined to "hard plumb" the sewer line as this is a 5th wheel not a mobile home, and we intend to keep it that way.
How much propane do ya'll go through running the furnace? We're going to heat primarily with electric heaters as our power is free, but will need to augment with propane. I'm also making an assumption I can tap one of the propane lines to a 250# pig vice the little 20# toy that comes with the camper? Anyone have an extend-a-stay kit on one of these?
How much power does the unit draw collapsing slides? I need to buy the right sized generator. I'm probably going to get a 15kw (to power the 385, ice castle, block heaters, trickle charges, cargo trailer, etc), but in case I decide to get a normal human sized generator, how power much to collapse slides/retract jacks?
Chris Columbus, do you know what the roof/slide load numbers are for snow/ice? We've always just collapsed if more than a couple of inches are in the forecast and will continue to do so, but just for my edification. Also, we've replaced our fair share of converters over the years. Would it be better to put the batteries on a trickle charger like the trucks or leave them on the coach's system? Can I mix the two with the 385's system? Also just to be clear, I'm disconnecting the batteries (via the switch) after we're on shore power, correct?
Any advice/comments?
PS ParkMan the wife is from Montreal!
ID:	20866   Click image for larger version
Old 10-20-2012, 05:51 AM   #7
Earth Station's Avatar
WOW........ looking forward to hearing about your winter!!!! We love our Columbus but it will be winterized in November. And we are much further south than you!! keep us all posted......
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 10-20-2012, 07:17 AM   #8
Campin' in Canada
ParkManCan's Avatar
Montreal eh? Get it? "eh!" haha
Permanently Parked
Just me & the DW
Old 10-20-2012, 07:17 AM   #9
Patrickdana's Avatar
Very interesting. Just wondering if the bales of straw/hay will attract field rodents?
Wintering in Florida in a 325rl.
For God hath not given us the spirit of fear; but of power, and of love, and of a sound mind. 2Timothy 1:7
Patrickdana is offline   Reply With Quote
Old 10-20-2012, 08:27 AM   #10
Well yes this is a concern; however, at this point we are most concerned with preventing as much ground freezing as possible. Standard foam insulation just won't cover enough of a footprint for the associated costs, and may yet attract rodents. This is an issue that is on our radar, and may be simply solved by means of the cats/birds around the campground. If it would only snow and actually stick we may only need foam. My concern with the hay is what to do with it come spring...
We'll probably end up trapping many a poor mouse this winter, but that would only mean our plan is working.
Old 10-20-2012, 08:51 AM   #11
keep camping's Avatar
My Dad worked/lived a couple winters out in western North Dakota in a Terry tt. He's a plumber, so he skirted w/ insulation sheets, used bales, heat tape. Installed some electric baseboards etc. didn't have any problems, so it's doable! Besides NOAA is predicting above average temps for MN this year, that'll help a little. Keep us posted.
2 Happy Campers & CoCoa the camping Yorkiepoo
2005 Salem LE 19FD
2009 Ford F150 Lariat
keep camping is offline   Reply With Quote
Old 10-20-2012, 09:09 AM   #12
Trailer Trash
Although the Columbus units have a enclosed and heated underbelly and holding tank heaters..............My 320RS has little insulation. The R factor on these units is pretty low as they do not come with a winter package. R factory is on the specs of the 2013 brochure as I recall. Don't know if you can spec extra insulation on a new factory build. In late September nights got down to 38-45 degrees. Furnace was set at 63 degrees. Went through a 20lb tank in 3 nites. Only other thing using propane was water heater and I shut that off at nite.
Regarding the Ford 6.0 - I have a 2006. It's VERY well documented what goes wrong with these engines and what you have to do to bullet proof them.
Im in Buffalo MN so send me an email to [moderator edit / Please use PM system] for trading contact info. Love to come up and visit ya this winter.
joelek is offline   Reply With Quote
Old 10-20-2012, 11:00 AM   #13
GlacierGus's Avatar
Welcome from south central Mn. This should be quite a winter for you. I would be interested in following your adventures. As a skiier, I am hoping for lots of snow. I would enjoy seeing a picture of your place this winter with piles of snow around your foundation. Have fun..and good luck!
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 10-20-2012, 05:26 PM   #14
I have been in the underbelly of my 325rk. It has 4" of fiberglass insulation on the very bottom then the underbelly area then the foam insulation against the floor. 1500 watt electric heater kept us comfortable at 38 degrees in the mountains.
Old 10-20-2012, 06:03 PM   #15
Factory Rep
Insulation in the floor.
Block foam in main floor you walk on.
2 layers of spun Fiberglas insulation in underbelly
Bubble / alum foil insulation below
Heater from furnace vents into basement
Electric heater pad on each tank in basement
Chris
Christopher Columbus is offline   Reply With Quote
Old 10-20-2012, 06:35 PM   #16
[QUOTE=joelek;266365]
QUOTE]
Yeah I know, we found a 2004 F350 DRW Crew Cab with 82000 miles that has lived a garaged life and only towed an amateur race car team around. $18,000 couldn't pass that up. I'm fortunate enough to have a master mechanic as my co-worker and drinking buddy, so I'm in a good place. Plus I grew up with Land Rovers, so I don't care how bad the 6.0 gets, it cannot be more of a maintenance hog than a Landie. I'm also fortunate enough to have the time/resources to throw into this truck. So we're willing to gamble a bit on the beast. If it fails, we can re-address with a newer F350 with the 6.7, but I think this truck will outlast me.
I'll email you tonight while I'm suppoesd to be "working" .
Old 10-20-2012, 06:42 PM   #17
Chris
As always thanks Chris. Compared to the Itasca, the 385 is going to be significantly warmer.
Old 10-21-2012, 12:13 PM   #18
Trailer Trash
I gambled on my 6.0 also and bought a 2 year 12K mile warranty with the truck. Poor guys are WAY upside down on the warranty repairs - aka I am way ahead. Truck runs very well now!
I saw the new Ice Castles at Milaca Unclaimed Freight a few weeks ago. Those rigs are the ultimate man cave on ice.
Old 10-21-2012, 02:16 PM   #19
Factory Rep
Gypsy Family
I hope you ordered the dual pane windows They will help you so much in the very cold cold days you may encounter.
Chris
Old 10-21-2012, 09:35 PM   #20
Gypsy Family
Chris
We bought it off the lot vice ordering it so we get what we get, and I don't think we have the dual pane windows (not on the spec sheet). Odd given it's coming from a dealer in Duluth, but I think we can make due without, we've never had dual paned windows before (never been to -35 before though). I understand it would be probably quite expensive, but could dual pane windows be added in the future if we find we're loosing too much heat/AC to the windows?
Also is there any consideration we should give to building up ice on the slide tracks?
Thanks in advance.
