Old 08-19-2018, 09:23 PM   #1
Duramax2017's Avatar
Odor from sinks 383FB
Palomino Columbus 383FB rotten egg smell coming from faucets at dual sinks in bathroom when running water only, finely goes away after running water for a awhile. any suggestions
Duramax2017 is offline   Reply With Quote
Old 08-19-2018, 09:31 PM   #2
Not a newbie
Johnfort's Avatar
Look it up on YouTube, there is a vinegar flush video for the water heater that will solve your problem. Also, get a flush wand for the WH to clean it and replace the aneroid.
Johnfort is online now   Reply With Quote
Old 08-19-2018, 10:30 PM   #3
Thank You I will get that done
Old 08-19-2018, 11:13 PM   #4
Not a newbie
Johnfort's Avatar
Atwood WHs do not have an aneroid, but Suburbans do.
Old 08-19-2018, 11:50 PM   #5
amxpress's Avatar
That smell will also generate from the washing machine water lines, especially if you donít have a washing machine. Flush out both lines which should eliminate the odor.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 08-20-2018, 06:30 PM   #6
This is often caused by the AAV (air admittance valve) under the sink needed to be replaced. Cheap and easy. Do a search on the forum for photos.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 08-21-2018, 09:28 PM   #7
flushed the hot water heater today hope that takes care of the smell going to do the washing machine lines also, thanks for all the suggestions
Old 08-21-2018, 09:35 PM   #8
Not a newbie
Johnfort's Avatar
Hope that works for you.
Old 08-21-2018, 10:37 PM   #9
me to I didn't get a lot of junk out of it flushed it for about 15 min. the coach is only a about a year old anode rod looked good.
Old 08-24-2018, 08:59 PM   #10
Flushed the hot water heater today did not help the smell I will try the washer hook up don't have a washing machine hooked up the smell is like rotten eggs and rubber hoses bath room sinks only
sink
