Old 01-29-2013, 12:34 PM   #61
SYE
SYE's Avatar
Here is the pic of it
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 01-29-2013, 02:49 PM   #62
dan747's Avatar
Looks perfect! I asked about size because it seems that tv's of the same rated screen size have different outside dimensions. Did you put your own tv in there? If so, did Columbus provide a mount or did you get your own?
Dan & Trish
2006 F-250 Lariat 6.0 Powerstroke
2011 Prime Time 260rld Crusader
Columbus 320RS on order
dan747 is offline   Reply With Quote
Old 01-29-2013, 03:19 PM   #63
captbenjy's Avatar
My 320rs has the slide awnings. After taking it for its maiden voyage last weekend under pine trees I'm glad it has them. Added protection and less to worry about IMO.
2013 Columbus 320RS "The Wonder Wagon"
2009 F-250 4WD (Tuned) "Black Beauty"
captbenjy is offline   Reply With Quote
Old 01-29-2013, 04:50 PM   #64
SYE
SYE's Avatar
I purchased it direct from columbus, mount and all. The TV is a Hisense you can go onto walmart.com to get the approximate dimensions. 32 inch LCD tv
Scott & Vicki
2021 4 reserved
Old 01-29-2013, 05:36 PM   #65
amxpress's Avatar
We have slide toppers on our 320RS and find them to be very beneficial. I use to climb on the too. I use to climb on the roof when staying under pine needles or nuts & berrys droppings to clean off the slide tops. Now I don't have to worry about trash on the slide tops damaging the seals or brought inside. They're worth it to me.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 01-29-2013, 09:35 PM   #66
How many of you Columbus owners out there have the slide out awnings? If you have them has it been worth the extra cost. Looks like $1200 for all three if installed during build. Also has anybody noticed that the bedroom slide out causes it to be much colder or hotter in that area compared to the rest of the trailer?
Does anybody have the dimensions of the tv box in the bedroom? I want to buy a tv before the trailer arrives so I can install and check during PDI.
Thanks for all your help!
I put a 32 inch in the bedroom fits perfect.
Cuttinchief is offline   Reply With Quote
320rs, columbus, newbie, palomino, pdi
