Old 10-29-2013, 09:23 PM   #11
QCCowboy's Avatar
Originally Posted by 5 hole View Post
Thanks QC... I really like the stove top look, as it expands the counter space so much when not in use. Since I tend to cook outside most of the time, think this is a good spot for the coffe maker!
We do a lot of cooking outside as well. One simple mod I would recommend for you is adding a pop-a-plate under the cabinets (below the microwave) in the OK....saves space and makes easy access to paper plates without having to go inside all the time. We also keep a small basket with forks, spoons, knives and napkins on the counter there as well.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 10-29-2013, 10:23 PM   #12
5 hole's Avatar
Have you done this QC? Do you have a link?
5 hole is offline   Reply With Quote
Old 10-29-2013, 10:26 PM   #13
QCCowboy's Avatar
Yep. Dont have pics and our camper is in its resting spot for the winter.
Here is the link.... Really pricey
http://www.amazon.com/gp/aw/d/B00094I1SA
2014 Sabre 36QBOK
Old 10-30-2013, 09:27 AM   #14
5 hole's Avatar
ahhhh ok!! I was thinking home made job... hahaha thanks!
Old 10-30-2013, 05:22 PM   #15
Here to Help
Originally posted in reply to the 'new floorplan thread', realized I should give it a new topic. This is in the new Pebble Fabric/interior. Stove top is recessed with a glass top now. Fridge no longer has wood panel. Subwoofer area has moved? A few other changes from 2013. Will be delivered in mid Nov Can anyone tell me is the LED rope lighting under the awning new?
Yes the awning LED lights are new and only white.
SabreSam is offline   Reply With Quote
Old 10-30-2013, 06:24 PM   #16
I have a feeling I know the answer to this, but does anybody know how involved it would be to change the lights to a different color (after you already own the camper?) Not a big fan of the bright white lights. Hey Palomino- tell the awning maker to include LED's that can be changed to different colors. That would be a fantastic option.
campingguy is offline   Reply With Quote
Old 10-30-2013, 06:29 PM   #17
Fulltime family RVer
Depending on the mounting, you can likely put your own multi-colored just below/behind the factory issues ones. I think Herk did that on his aftermarket installed lights - he uses 2 strips.
Or, you could do the awning tube install of the RGB ones.
ependydad is online now   Reply With Quote
Old 10-30-2013, 07:38 PM   #18
5 hole's Avatar
Does anyone know if the 'slide strip' issue affects the Sabre line as well? Has Factory fixed this on production yet? I will take a look at mine when delivered to see...
Old 10-30-2013, 07:49 PM   #19
Which issue are you referring to?
Old 10-30-2013, 08:33 PM   #20
5 hole's Avatar
The white plastic slide pieces that are disintegrating and having screws pull through etc. Several thread on here about this about quick wear and damage being done..
