Old 10-29-2013, 11:27 AM   #1
5 hole's Avatar
Our new 2014 36QBOK - Photos
Originally posted in reply to the 'new floorplan thread', realized I should give it a new topic.
This is in the new Pebble Fabric/interior. Stove top is recessed with a glass top now. Fridge no longer has wood panel. Subwoofer area has moved? A few other changes from 2013.
Will be delivered in mid Nov
Can anyone tell me is the LED rope lighting under the awning new?
ID:	42004   Click image for larger version
ID:	42005   Click image for larger version
ID:	42006   Click image for larger version
ID:	42007   Click image for larger version
ID:	42009   Click image for larger version
ID:	42010   Click image for larger version
ID:	42011   Click image for larger version
ID:	42012   Click image for larger version
5 hole is offline   Reply With Quote
Old 10-29-2013, 11:30 AM   #2
5 hole's Avatar
Also, ceiling fan now has lights..
love the new walls with the striated look vs the 'blotchy' look
ID:	42014   Click image for larger version
ID:	42015   Click image for larger version
ID:	42016   Click image for larger version
ID:	42017   Click image for larger version
ID:	42020   Click image for larger version
ID:	42021   Click image for larger version
ID:	42022   Click image for larger version
Old 10-29-2013, 11:44 AM   #3
5 hole's Avatar
Other things.... They have added a recessed halogen light to kitchen area.
Love the new smoked glass look for the 'entertainment' cabinetry vs the old frosted visual.
Old 10-29-2013, 11:55 AM   #4
QCCowboy's Avatar
Congrats on the new QBOK. I like the changes. Really like the stovetop! As for the rope lights, they must be new as I have seen a few different campers with the LED's on from the factory now. Will be curious if they are just the White LED's that I have seen on other units or if they change colors like the ones that several of us have done as mods.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 10-29-2013, 11:58 AM   #5
5 hole's Avatar
Thanks QC... I really like the stove top look, as it expands the counter space so much when not in use. Since I tend to cook outside most of the time, think this is a good spot for the coffe maker!
Old 10-29-2013, 12:26 PM   #6
Minnesotan
Looks very snazzy. Congrats!
kaschultz is offline   Reply With Quote
Old 10-29-2013, 12:38 PM   #7
Witch Doctor's Avatar
They are just white is my understanding, not like the ones that change color. But they are still nice and you could probably add a dimmer if to bright. FR seems to be putting them in more and more. They probably got the idea off this forum.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-29-2013, 02:11 PM   #8
Fulltime family RVer
I bet there's a lot of truth in that! I know that I've sent the Sabre factory reps a ton of input after owning my camper for a few months. I'd bet that 80% of them ended up as changes or options in the later models.
ependydad is online now   Reply With Quote
Old 10-29-2013, 07:31 PM   #9
I really like the look of the new cooktop top!
Old 10-29-2013, 08:22 PM   #10
Oklahoma Proud
MillerTime's Avatar
Pretty sweet!!!
I cant wait to order 36. Hoping to place order in jan or feb so I wont have to winterize after pdi. Plus I dont really need till late spring.
Congrats, shes a beauty!
Old 10-29-2013, 09:23 PM   #11
QCCowboy's Avatar
We do a lot of cooking outside as well. One simple mod I would recommend for you is adding a pop-a-plate under the cabinets (below the microwave) in the OK....saves space and makes easy access to paper plates without having to go inside all the time. We also keep a small basket with forks, spoons, knives and napkins on the counter there as well.
2014 Sabre 36QBOK
Old 10-29-2013, 10:23 PM   #12
5 hole's Avatar
Have you done this QC? Do you have a link?
Old 10-29-2013, 10:26 PM   #13
QCCowboy's Avatar
Yep. Dont have pics and our camper is in its resting spot for the winter.
Here is the link.... Really pricey
http://www.amazon.com/gp/aw/d/B00094I1SA
2014 Sabre 36QBOK
Old 10-30-2013, 09:27 AM   #14
5 hole's Avatar
ahhhh ok!! I was thinking home made job... hahaha thanks!
Old 10-30-2013, 05:22 PM   #15
Here to Help
Originally posted in reply to the 'new floorplan thread', realized I should give it a new topic. This is in the new Pebble Fabric/interior. Stove top is recessed with a glass top now. Fridge no longer has wood panel. Subwoofer area has moved? A few other changes from 2013. Will be delivered in mid Nov Can anyone tell me is the LED rope lighting under the awning new?
Yes the awning LED lights are new and only white.
SabreSam is offline   Reply With Quote
Old 10-30-2013, 06:24 PM   #16
I have a feeling I know the answer to this, but does anybody know how involved it would be to change the lights to a different color (after you already own the camper?) Not a big fan of the bright white lights. Hey Palomino- tell the awning maker to include LED's that can be changed to different colors. That would be a fantastic option.
campingguy is offline   Reply With Quote
Old 10-30-2013, 06:29 PM   #17
Depending on the mounting, you can likely put your own multi-colored just below/behind the factory issues ones. I think Herk did that on his aftermarket installed lights - he uses 2 strips.
Or, you could do the awning tube install of the RGB ones.
Old 10-30-2013, 07:38 PM   #18
5 hole's Avatar
Does anyone know if the 'slide strip' issue affects the Sabre line as well? Has Factory fixed this on production yet? I will take a look at mine when delivered to see...
Old 10-30-2013, 07:49 PM   #19
Which issue are you referring to?
Old 10-30-2013, 08:33 PM   #20
5 hole's Avatar
The white plastic slide pieces that are disintegrating and having screws pull through etc. Several thread on here about this about quick wear and damage being done..
