Old 04-03-2014, 11:49 AM   #11
Originally Posted by QCCowboy View Post
Any screws to take the paneling off? Used to have to do this to get to my hot water heater.
Not so simple, there is a built in ladder with several layers of framing and trim on the inside. Then there are cabinets hanging above the outdoor sink.
Good suggestion though.
dleitermann is offline   Reply With Quote
Old 04-03-2014, 11:57 AM   #12
Fulltime family RVer
The only other thing that I can think for simply seeing is a smart phone. I've used mine to take blind pictures and then deciphering them afterwards.
Doesn't help with the fix, though.
Have you guys tried pulling the sink up from where its installed?
Old 04-03-2014, 12:00 PM   #13
Originally Posted by pjones1969 View Post
It is a bit tight back there! I probably need to take a better look and see if I have any issues on our next trip.
You're right it is VERY tight. The leak must be coming from the faucet as we've tested the drain separately and that does not leak.
Old 04-03-2014, 12:23 PM   #14
Will give this a try!
Old 04-03-2014, 12:55 PM   #15
Brother Les's Avatar
The sink should be only held in place by some screws on the bottom of the sink (mine is). Remove the screws and lift up the sink bowl and check under it for any leaks with the lines under water pressure. All of the front (outside) panels will come out easily and any drawers will come out easily for more room to work.
Brother Les
Old 04-14-2014, 12:37 PM   #16
Update to outdoor kitchen sink. It was a VERY easy fix. Just replaced an O-ring in the faucet handle.
Sometimes you think the fix is going to be much worse than it actually is.
Old 04-14-2014, 01:20 PM   #17
Thanks for the update! Glad you all were able to get to it.
door, faucet, leak
