Old 04-02-2014, 12:47 PM   #1
Outdoor kitchen sink/faucet leak on 2011 32BHOK-6
Last fall we noticed water seeping under the cabinet in front of the kitchen sink. We pulled the small front panel off to get under the sink. I have small hands and can get my hand under the sink but not able to find or see where the leak is.
From what my hubby and I can tell, there is no way to access this area unless the whole cabinetry is taken apart. That is way beyond our comfort level.
I'm looking to see if anyone has had a similar problem and what the solution was.
With this brutal winter we have not been able to unwinterize it. We still have some snow.
dleitermann is offline   Reply With Quote
Old 04-02-2014, 01:39 PM   #2
jtstromsburg's Avatar
I can't look at mine right now, but would see about loosening the drain line and removing the sink with faucet attached to get a better look?
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-02-2014, 02:06 PM   #3
caper's Avatar
Why not rent an inspection camera similar to the one shown. The small end can be inserted into the small opening and it also has a built in light. Will make quick work and you do not have to take the cabinets apart.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-02-2014, 02:29 PM   #4
Fulltime family RVer
Do you have a drawer inside behind the outside kitchen? My 36QB does- if I take that out, I can see inside and possibly work the area (it'd be snug, real snug if not impossible).
ependydad is online now   Reply With Quote
Old 04-02-2014, 02:57 PM   #5
Great ideas. We will give them a try.
Old 04-02-2014, 02:59 PM   #6
No drawers behind. There is a bunk above it and paneling beneath the bunk.
Old 04-02-2014, 03:17 PM   #7
QCCowboy's Avatar
Any screws to take the paneling off? Used to have to do this to get to my hot water heater.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-02-2014, 08:58 PM   #8
pjones1969's Avatar
Not familiar with the 2011 OK but on my 2013 32bhok there are two drawers to the left of the sink that can be pulled out and a removable access panel right in front of the sink, just retread your post, looks like you have tried going through the access panel.
Name:	ImageUploadedByForest River Forums1396490212.215784.jpg
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 04-03-2014, 11:43 AM   #9
Attachment 49041
Same set up as yours. We did take the panel off as you state. Not enough space to feel the leak.
We tried using a small mirror but that didn't help either.
Old 04-03-2014, 11:47 AM   #10
pjones1969's Avatar
It is a bit tight back there! I probably need to take a better look and see if I have any issues on our next trip.
B&W Companion
Old 04-03-2014, 11:49 AM   #11
Not so simple, there is a built in ladder with several layers of framing and trim on the inside. Then there are cabinets hanging above the outdoor sink.
Good suggestion though.
Old 04-03-2014, 11:57 AM   #12
The only other thing that I can think for simply seeing is a smart phone. I've used mine to take blind pictures and then deciphering them afterwards.
Doesn't help with the fix, though.
Have you guys tried pulling the sink up from where its installed?
Old 04-03-2014, 12:00 PM   #13
You're right it is VERY tight. The leak must be coming from the faucet as we've tested the drain separately and that does not leak.
Old 04-03-2014, 12:23 PM   #14
Will give this a try!
Old 04-03-2014, 12:55 PM   #15
Brother Les's Avatar
The sink should be only held in place by some screws on the bottom of the sink (mine is). Remove the screws and lift up the sink bowl and check under it for any leaks with the lines under water pressure. All of the front (outside) panels will come out easily and any drawers will come out easily for more room to work.
Brother Les
Old 04-14-2014, 12:37 PM   #16
Update to outdoor kitchen sink. It was a VERY easy fix. Just replaced an O-ring in the faucet handle.
Sometimes you think the fix is going to be much worse than it actually is.
Old 04-14-2014, 01:20 PM   #17
Thanks for the update! Glad you all were able to get to it.
door, faucet, leak
