Old 03-07-2015, 10:38 AM   #1
Oven pilot light
My oven pilot light will light but it goes out once the burner cycles. Does anybody know how to adjust it?
Brandon327 is offline   Reply With Quote
Old 03-07-2015, 10:57 AM   #2
member
Sounds like what was happing with mine . Mine would go out after the Brunner was lit for a few min. Dealer replaced the thermal couple all was well.
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 03-07-2015, 11:40 AM   #3
My pilot does burn tall enough to do any good.
Old 03-07-2015, 12:08 PM   #4
VinceU's Avatar
It may be less than a 1/4" ball of blue flame, if close enough to the thermocouple it will work just fine.
Old 03-07-2015, 12:35 PM   #5
Witch Doctor's Avatar
THe first 1/4" of the thermocouple is empty so make sure you have it correct. take the part off at the valve and clean any corrosion at the nut on the valve. Sand paper both ends and reinstall it, New one cost about 10.00 at ace. Difference is only the length not the millivolts. just wind it up if to long.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-07-2015, 12:58 PM   #6
The thermocouple is fine . I need to know where the screw is to adjust the pilot flame .
light
