Old 04-17-2019, 11:15 AM   #1
Overhead LED lights quit working
I have a 2017 Columbus Compass. The light in the kitchen quit working after flickering for a few weeks. I check fuses, all good. I understand that they work in a series? So my question is how to tell which one is burned out.
Randolyn is offline   Reply With Quote
Old 08-15-2019, 07:12 PM   #2
Had the same , had to order new led bulb (unit ) since the are not bulbs
rogerramjet442 is offline   Reply With Quote
Old 08-15-2019, 08:20 PM   #3
Have all your lights quit or just the one in the kitchen?
They are not really wired in series like Christmas lights meaning if one goes out, they all go out. Not so.
They usually are wired in parallel and current flows to the next light even if one burns out.
Have you tested for voltage at the light?
Do you own a multimeter and know how to use it?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 08-17-2019, 07:15 AM   #4
I have read in a few places that some led lights start flickering because of faulty electronics that run the lights. The only real way to fix them is to replace them. Most likely you’ll have to replace the unit that is flickering. This is not isolated to RVs and also occurs in homes as well.
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
tjwoody is offline   Reply With Quote
led, light
