Old 06-23-2012, 05:52 AM   #11
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
First of all Chaps - welcome to the Forum. I've just been a member since we ordered our Columbus. You have made a decision that I hope you will enjoy as much as we have...buying a Columbus 320RS. What a great fifth wheel this is!! We're heading out tomorrow for a full week on the road...and look forward to every opportunity to get it out.
I'm glad to answer any questions you have to the best of my knowledge:
1: Are you satisfied how your truck does the job? - 100% satisfied. We pulled a Travel Trailer for 3 years before getting our first 5th Wheel. We pulled that Sandpiper Fiver for 6 years. First with another F250 and the last couple of years with our current one. No hesitation to take it anywhere that we've been so far.
2: Have you towed thru any high country, such as Smokies, Rockies, etc.? - No...the wife is not much of one for mountains even without a trailer behind us. We do travel the Texas Hill Country frequently and they have some significant inclines, but not true "mountains" or high country. I can tell you...with our 250 we have no problem passing other vehicles (if necessary) while climbing the inclines and pulling the Columbus.
3: Is yours the 6 & 3/4 or 8' bed & if it is the shortbed, do your have a slider hitch or use any extended pin box such as a sidewinder, etc.? - We've got the short bed and yes we do have the slider hitch, but I haven't used that since the first year we had a fifth wheel. It just never has been needed...and I have to back down a narrow, tree-lined driveway over 150' every time we get ready to head out. The Columbus has an even better backing/turning radius than the Sandpiper had.
4: What axle ratio does your diesel have - 3.55 or lower? - 3.55
5: Have you upgraded the trucks suspension at all (other than probably having Ford's camper package suspension) such as installing air bags or something like Torklift's Stable Load, etc.? - No modifications at all have been done to the truck beyond adding the 5th wheel in the bed...and the seven-way plug in the bed.
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017: 712 ~ Nights Camping 2018: 41
rjshiflet is offline   Reply With Quote
Old 06-23-2012, 08:02 AM   #12
hotrodj125's Avatar
Originally Posted by TheEdge View Post
I"m in the process of ordering the 320RS fifth wheel and need some input from current owners regarding the different leveling systems.
The salesman I'm dealing with has told me there are problems with the 6 way leveling system and that I should go with the manual system instead.
This seems crazy to me. I would think if the 6 way system is a problem I should at least go with the 4 way auto leveling system.
Can current owners tell me about your experience and recommendations for the best leveling setup?
Thanks folks, and have a great weekend.
We have the 4-way; which works just fine and does a great job. Sometiomes more is not better- actually- all the more to go wrong or have trouble with and the added extra weight to pull around.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 06-23-2012, 11:03 AM   #13
"On the road again"
rjshiflet's Avatar
Regarding the leveling system...I went with the 6-way (basically the same price as the 4-way at my dealership) and I wouldn't take for it. We've been out several times, plus leveling it in the driveway and it has never failed to be within 0.1 degree of level either side to side or front to rear. Normally...it is 0.0.
One point of clarification that I didn't understand when I ordered it...the six-way is basically nothing more than a four-way leveling system - but it has the additional two legs as to stabilize. After the front and rear finish adjusting...it then adjusts the center two legs to stabilize the unit.
We also have the standard 5th wheel tripod on the kingpin and we get ZERO bounce or movement as we walk through the trailer...upstairs or downstairs.
My advice...go with the six-way. It's a breeze to use and you'll really enjoy it.
But...the bottom line, it's your rig - you'll be using it so it's your decision.
Old 06-23-2012, 05:24 PM   #14
Columbus 302 rs
Thanks again for everyone's input. We ordered the 4way, but I'm confident from what's been said here that the 6 way is also solid.
The info about trucks and everything else on this forum is a great education as we will be first timers and expect our unit at the end of July or first week of August.
I'm sure I'll have a ton of other questions. Right now i'm looking for a nice King Ranch F350 about 2008 for pulling.
TheEdge is offline   Reply With Quote
Old 09-05-2012, 04:07 PM   #15
Originally Posted by rjshiflet View Post
I have the Columbus 320RS with the six-way and I LOVE IT!!!!!!
Not sure what your sales guy is trying to accomplish, but our Lippert six-way is tremendous. We get to a location...unhook...drop the middle and back legs down generally about half-way with the quick-release...and then push AUTO-LEVEL and for the next minute or two while it's leveling I can be getting other things done.
With our previous fifth wheel we always had to pull one side or the other up on the yellow blocks...no wait, we need TWO blocks...oops...that's too much...scoot over to the left more and see if that works.
Our Lippert has yet to fail and it is always within 0.1 degree of level.
The extra stability (especially with the kingpin tripod we've now added) is amazing. We have ZERO movement as we walk around in the trailer.
GET THE SIX-WAY...forget what the sales guy tells you. You'll kick yourself if you don't.
Hey guys, how are you. With the 6 way leveling system, what do you use under them, i.e., square 2x6, two, etc? do you carry extra blocks with you? I am not sure if you camp on mostly level places or not. Thanks
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
Old 09-05-2012, 10:34 PM   #16
Columbus 302 rs
Based on our salesmens recommendation we ordered the four way leveling system. When we arrived to pickup the 320rs it didn't have any leveling system. The salesman tried to tell me that the stabilization jacks were the leveling system. He must have thought I was an idiot since I'm a newby.
Whole lot more to our experences with this salesman.
When we are ready we will do an aftermarket leveling system, probably in late October or November.
Old 09-05-2012, 11:04 PM   #17
amxpress's Avatar
With all due respect your salesman sounds , well...like a typical salesman. I had JT Strong arm stabilizers installed this week.
Looking forward to seeing how well they work
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-07-2012, 08:19 PM   #18
Columbus 302 rs
I will be anxious to hear how the JL's work for you.Been thinking about them either without or with a leveling system.
I'm also curious about the weight of each type of system.
Our next purchase will probably be a satellite antenna with dish network and than resolve what we want to do for leveling and or stabilization.
Old 09-14-2012, 03:15 PM   #19
"On the road again"
rjshiflet's Avatar
We generally don't use anything beneath them, unless we're on really sandy soil or in case there is a really uneven spot we're camping, then we generally have some wooden blocks or the yellow plastic "Lego-looking" RV blocks. Several years ago I came across some discarded 3x12 pieces of lumber a foot to 15" long and snagged those. We toss them into the back of the truck to have just in case (unless it's somewhere we've been before and know it's pretty level).
320rs, columbus, jacks, leveling
