Old 06-08-2015, 09:20 PM   #1
Moose509's Avatar
Palomino Sabre converter question
Question to all those out there that has much more knowledge about converters than I. 2011 Palamino Sabre 31RETS 50 amp - only one AC. Which Progressive Dynamics converter would be correct for my 5er? 30 Amp / 45 AMP / 60 Amp / 70 Amp / 80 Amp?? Any and all help and advise is welcomed.
Thanks!
2006 Ford F-250 Super Duty 6.0L
Moose509 is offline   Reply With Quote
Old 06-09-2015, 02:58 AM   #2
Witch Doctor's Avatar
Thanks!
I would go with 60 or 70 amp. 60 with 1 battery and 70 if you have two. I have seen people go with 70 for a single battery replacement. If you are plugged in all the time 60 for sure. If your going to be needing alot of charging such as boondocking I would then go for 70 amp. Much faster charge from 55 to 70 amp...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-09-2015, 08:02 PM   #3
Moose509's Avatar
Next questions which is the better converter to purchase WFCO - PD - or what.
One thread stated the WFCO were in Forest River RV for a reason, cost.
Thanks!
Old 06-09-2015, 08:15 PM   #4
TURBS's Avatar
Ah yes another wfco bites the dust!
Progressive 60-70 amp
Do not buy another junk wfco !
http://progressivedyn.com/mobi/rv_co..._pd9270_2.html
Also get the charge wizard pendant.
http://www.progressivedyn.com/prod_details/pendant.html
You cannot go wrong with the 60 either, that is what I've used in the past.
http://www.progressivedyn.com/rv_con...pd9260c_2.html
Check here for pricing.
http://www.bestconverter.com/Progres...ters_c_81.html
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-10-2015, 03:00 AM   #5
Thanks!
That was a main reason at one time. But now FR is slowly switching over to a progressive model. They have been testing them on certain units. I'm sure the cost is minimal to them between the two. They are going to also be changing over to jack antennas on all units also, they are still testing them. I have to give them credit atleast they are tring....
Coachmen M/H
Concord
2018 / 300 DSC
